2wd in the sand?
Discussion in 'Off-Roading & Trails' started by Burgman, May 3, 2009.
2wd on the beach?
  1. No problem
    158 vote(s)
    17.7%
  2. Could have some trouble
    537 vote(s)
    60.1%
  3. Dont try
    199 vote(s)
    22.3%
  1. Jan 17, 2013 at 11:28 PM
    #261
    DJSPEC
    DJSPEC 808 Zombie Outbreak Tactical Response Team K9 Unit
    Sean G
    Kaimuki,Hawaii
    2011 TRD Sport DCSB 4x4 & 2014 TRD SPORT DCSB & 2016 TRD-OR AC 4x4
    debadged Viper Alarm Diehard Platinum 31M Battery Pelfreybilt Battery Cage OEM roof racks, step sides LED HI/LO Headlights 35W 6000k HID Fog Lights 20% tint Front windows 5% tint rear windows 2 Sets of Rigid Industries D2 above the valance Duallys on Famous Fabrication's Hood Hinge Brackets Rigid Industries SR2 10" in HoodScoop with C4 Fabrications Hood Scoop Bracket Flowmasters Super 44 series 9942446) Dueler A/T REVO2 265/70R17 SCS Stealth 6 Wheels Wet Okole Seat Covers Reese Tow Hitch 33090 Plastidip Front Valance FoglightMod(Fuel Pump Relay Version) Kobalt Slim Tool Box Matt Gecko Truck Bed LED Kit and Sliding Window Security Bar 3" Lift Light Racing Ball-Joint Upper Control Arms (LR8-25470) OME Front Nitro Shock(900021) with 885 Springs OME Nitro Rear Shocks (ARB8-60091) Revtek Add-A-Leaf (REVAALT5B)
    in hawaii, @ 30psi, and in 2wd, i was driving along in the sand and started to slow down and started to get stuck, until i switched to 4wd and that pulled me out. I got a mini battery pump but was too lazy to air down. lol
  2. Feb 7, 2013 at 8:09 PM
    #262
    bigeye227
    bigeye227 bigeye227
    Charlie
    Kernersville, NC
    2011 TRD Off Road
    Banks Exhaust, K&N CAI, Custom Mud Flaps, Weather Techs
    It's all about air pressure. About 15#. Clearance is pretty important as well. 2wd will work most of the time but towing on the beach on the east coast is expensive.
  3. Mar 1, 2013 at 7:53 AM
    #263
    JW87
    JW87 Well-Known Member
    JW
    Richmond,VA
    TRD Sport 4x4
    Tonneu cover, bed rug, all weather mats, antennax 13", and sil protectors.
    Had to pull my buddys prerunner out with my ranger down in obx, but it might have just been user error.
  4. Mar 1, 2013 at 8:20 AM
    #264
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 2 Hella 4000 HID, 1 Cibie Halogen. Bilstein 5100s Ride Rite Air Bags
    The user didn't deflate... NOBODY needs to be pulled out... as with enough of the air removed (provided you didn't spin the tires until your frame was resting on the sand), you can drive on sand in 2WD. If the sand is mixed with coral or shells, it is more difficult to not sink into, and even with 4WD, deflating may be needed. With my Dynapro ATMs, 18 psi is the sweet spot. With Rugged Trails, 15 psi. If you have a mud terrain tire, or 3 ply sidewall tire, then 10 psi... which is about what a 2WD will also need to deflate to. Just don't steer sharp, or slam on the brakes when deflated! Have a good pump to air back up. See my link below on 15 psi in sand...
  5. Mar 1, 2013 at 8:24 AM
    #265
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Depending on how deep or soft the sand is I would take a 2wd out regardless of tire pressure. Some places its a moot point because 2wd's are not even allowed on the beach.
  6. Mar 2, 2013 at 3:27 PM
    #266
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    I've done it a few times with my 4Runner. Got stuck ones. But had local braddahs that helped me push it out. After that. No more sand. Unless it's wet and compacted. Dry sand is a no go.
  7. Mar 3, 2013 at 4:11 PM
    #267
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    That's why I would use my quad on the sand
  8. Apr 2, 2013 at 11:58 PM
    #268
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    I use my locker in 2wd in the sand for like 30 seconds.. and when the skinny pedal is not enough I flip the 4x4 switch..
    soft sand and 2wd without low psi, large tires and a lot of power is not a good idea unless you have some 4x4 friends that dont mind pulling you out every 15 mins.
  9. Apr 12, 2013 at 12:58 AM
    #269
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    2wd in the sand, highway tires lowered to 15psi
    was good until i stopped to take a piss, then i couldnt get out lol
  10. Apr 13, 2013 at 9:51 AM
    #270
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 3 link SAS, F & R Diamond axles, ARB locked F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks, custom rear bumper and sliders that hold air.
    I have no issues w/ 5:29's, an ARB locker rolling on 285-75-16's @ 10 psi.
  11. Apr 13, 2013 at 11:51 AM
    #271
    Tacomada
    Tacomada Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Question for you sand junkies...
    Any time i am in sand and in 2wd, any wheel spin and the truck turns into a bucking bronco. Related to axle wrap I believe... Occasionally happens in 4wd as well. Just wondering how common this is for those of you who spend more time in the sand. I knows its terrible for the suspension and drive line.
  12. Apr 13, 2013 at 12:23 PM
    #272
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    It happens...you're right, I'm sure it's not good, I've found that you have to feather the throttle a bit to avoid it. There is a sweet spot tho, because too much and you'll just get stuck...better yet, if you can, air down and it will decrease aswell..
  13. Apr 13, 2013 at 3:14 PM
    #273
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Yeah. Seems worse with the springs weakening.
    I've never sure down my tires. Ill have to test it out one of these days
  14. Apr 13, 2013 at 3:25 PM
    #274
    gnstpd
    gnstpd Well-Known Member
    Lee
    El Paso, TX
    2012 Toyota Tacoma Prerunner Base Double Cab
    Stock For Now
    I live in El Paso and I'm in the desert all the time. As long you don't gun it you should be fine but there is always Murphy. I just upgrades to new tires and have less trouble now. But I do get stuck every once in a while.
  15. Apr 13, 2013 at 3:26 PM
    #275
    AWorthyOpponent
    Dan
    TRD Catback Exhaust
    Airing down your tires will prevent you from loosing traction in the first place, and the hop tends to stayin the tires since they're softer when aired down.
  16. Apr 15, 2013 at 10:56 AM
    #276
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Ya I find mine does it in certain snow conditions as well. Most of my offroad adventures don't entail enough sand to warrant airing down. But I am curious to try it.
  17. Apr 16, 2013 at 8:13 PM
    #277
    Johnsredline
    Johnsredline Well-Known Member
    North Las Vegas
    Barcelona Red- Method Double Standards, Flowmaster Exhaust, K&N intake, black headlights and raptor style grille, ICON stage 4 suspension, allpro sliders
    i have a 4x4 but do decent with just 2wd. but it totally depends on the type of sand. if your talking very loose sand, i wouldnt do it. but if your talking semi packed sand, like the flats in the sand dunes, you can do it if you know how to drive.
  18. May 3, 2013 at 3:27 PM
    #278
    Taco227
    Taco227 Well-Known Member
    Maryland
    TRD Sport
    3" Pro Comp suspension kit, 1.25" front wheel spacers, tinted clearance lights, 4 pioneer speakers, Sony head unit, Custom Sub enclosure with 10" MTX, dash kit, wicked flow exhaust, Firestone Airbags.
    Just a bad idea...tried it on the east coast..Assateague Island.
    Seen too many 2 wheel drive trucks stuck.
    Luckily I have the 4WD :)
  19. Jul 6, 2013 at 10:07 PM
    #279
    ajmartinez
    ajmartinez Engineer
    Anthony
    Katy, TX
    '13 V6 4x4 Manual TRD Off Road
    just don't stop. pulled three cars (and an F250 4x4) out of the sand today because they didn't keep a move on.
  20. Nov 25, 2013 at 11:53 AM
    #280
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    the sand out here is sugar sand......
    i see 100's of 4x4's stuck here every year
    2wd wouldnt get very far here
