2WD into a Prerunner?
Discussion in 'Suspension' started by jeepinoutwest, Oct 22, 2008.
  1. Oct 22, 2008 at 8:13 PM
    jeepinoutwest
    jeepinoutwest [OP] Well-Known Member
    Can anyone tell me how difficult it would be to turn my '08 2WD reg cab auto into a Prerunner? I am aware there are some aftermarket lifts available, but can I get the Toyota OEM hardware to do this project so it will be the same as a factory prerunner?
  2. Oct 22, 2008 at 10:42 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    I assume you have a 5 lug mini?
  3. Oct 22, 2008 at 11:08 PM
    br217398
    br217398 Crazy Person.....
    Orlando Florida
    06 Tundra Crew Cab 4WD
    Hornblasters horns,Strobe lights,Police Undercover Vehicle, Volent Ram air system, pro comp POS AAL, biltein all around, step bars.
    whats wrong with a 5lug mini??? heh i know it is possible with enough money, but last time i checked with toyota for prerunner parts it was near 2500 from the stealership... i myself have the 5base but its access cab so... were in the same boat
  4. Oct 23, 2008 at 4:20 AM
    jeepinoutwest
    yeah i have a 5 lugger. i just put 30x9.5 cooper STTs on her. They fit fine without a lift, i just think it would look better.
  5. Oct 23, 2008 at 4:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nothing wrong with the mini....but to the original poster...
    But you are SUA (spring UNDER axle). The Pre-runner is SOA (Spring OVER axle). So unless you can find a leaf spring pak that will give you about 5" of lift - then you'll have to do a SOA conversion which is a LOT OF WORK.
    Not only that - you'd have to find something to give you 5" of lift in the front also, which...I'm not sure that exists for your truck. I don't want to assume it's the same setup as the Prerunner with coilovers.
  6. Oct 23, 2008 at 5:23 AM
    Burns
    Burns Excellent Member
    17 DCSB Off-Road
    None!
  7. Oct 23, 2008 at 9:20 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Hey their,
    I wanted to do the same thing. I have a reg cab 2x4. I researched this a bit and went on a few forums.
    Here is a link to what was found.
    http://www.ttora.com/forum/showthread.php?t=113429
    Or see these kits
    See I found this becuase of people helping out and giving info.
    Total Chaose has the kit you want. $2600 ruffly. plus shocks/ springs
    http://www.socalsupertrucks.com/home.jsp this is 1 shop that sells them. you can look up others.
    http://www.downeyoff-road.com/SuspensionComponents/1995-04.html
    jd fab $2200 plus shock and springs
    http://jdfabrication.com/index.php?o...38&Itemi d=64
    Also all kits look like you will want Fender flares as well.
    Granted these are Long travel kits. but their is just not many Lift kits for these trucks. The 5Lug and 6Lug frames are not the same.. They have differant mounting points.
    From what I found you are better off selling your truck and buying a pre-runner or 4X4.... Unless you are rich. then you can do waht you want.
    Side note Skyjacker has a kit, but I am not sure who good or bad they are.
    Their is also a Spacer kit. but then again not sure how good or bad that is.
