2wd lift ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by saltbranch, Jun 12, 2011.
  1. Jun 12, 2011 at 8:28 PM
    saltbranch
    saltbranch [OP] Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    96', 2.4.5spd- just your basic taco. If we do a lift like the Fabtech, put on taller tires like my son wants....then arent we lookin at rear gearing the differential to bring the power back, esp in 5th gear on the hwy?
  2. Jun 12, 2011 at 8:30 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Depends on what size tires. But yes you should re gear
  3. Jun 12, 2011 at 8:36 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    i agree
  4. Jun 12, 2011 at 8:38 PM
    sir1123
    Charleston
    ecspecially with the 2.4
  5. Jun 14, 2011 at 2:23 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I put 235/75/R15s on my 2.4. It had a mild power loss but it really isn't bad. Still enough to spin the rear tires.
    I lifted mine with spindles and shackles. There's a link to it in my signature.
  6. Jun 14, 2011 at 2:28 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if you go to 31s you will be fine. anything bigger you should re gear on the 4 cylinder
  7. Jun 14, 2011 at 9:36 PM
    saltbranch
    Tx
    What brands are the better ones to go with? I dont mind spending some$$ for good setup. Just not sure whats out there. Only one I have really seen is the FabTech
  8. Jun 14, 2011 at 9:59 PM
    JBear
    JBear Spiral Out... Keep Going!
    Orange County, CA
    2003 Extra Cab 5 spd 4x4 TRD Off-Road
    2" suspension lift with King Coilovers up front. Standard Bilsteins on rear with a Fabtech 1.5" AAL. Leer 100XL Shell.
    Lifts are best achieved through front suspension upgrades and bigger leaf kits... or, like in my case, an add-a-leaf will do, lol.
  9. Jun 14, 2011 at 10:07 PM
    Blue
    Dylan
    Sierras
    Depends on how high you wanna go. Around 3" check out old man emu and bilstein with eibach coils. If you want to go higher than 3" you will need to go with a drop bracket lift (fabtech)
  10. Jun 14, 2011 at 10:50 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    I don't think any of those will work with a 5 lugger. Spindles up front and a new leaf pack or shackles/add a leaf depending on how worn your stock leaf pack is. New extended length rear shocks will be needed as well. I think only fabtech makes spindles for the 5 luggers. Fatbob's garage sells a lot of 5lugger lift components as well.
    Fabtech Spindles
    fat bobs garage
  11. Jun 15, 2011 at 12:06 PM
    Blue
    Dylan
    Sierras
    :facepalm: ahh didnt know he was a 5 lugger. My bad
  12. Jun 17, 2011 at 9:38 PM
    betardfoosier
    betardfoosier Well-Known Member
    Kansas
    2000 TRD SR5
    3" Skyjacker, 33x10.50 AT/TAs
    You will feel any tire size increase, I had a 4 cylinder ranger that I went up less than an inch, and it made an irritating difference in acceleration, especially passing. 4 cylinders have enough turning small tires on pickups, an increase in tire doesn't help. I went up 2 inches on my 3.4, and it made an enormous difference, despite what most people predicted. I always try to steer people away from lifting, unless they truly plan to wheel and do all the other proper upgrades to go along with.
  13. Jun 19, 2011 at 1:52 PM
    MowTaco
    Kansas
    I have fabtech spindles and I also found that Doetsch makes a kit
    http://www.doetsch-shocks.com/22.asp
    I also don't believe anyone makes spacers for the 1st gen 5 luggers... I searched pretty hard when deciding on what to do with mine.
  14. Jun 19, 2011 at 2:19 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    As For a lift on a 2wd 4 cyl. I would try to find a lift that will fit a 5-lug before worrying whether or not to regear. I have a 2.7 with a 2.5 inch suspension running 265's and i haven't had any noticeable power loss. And I'm also going to 33's here soon.
  15. Jun 22, 2011 at 6:49 PM
    crackberry
    crackberry Member
    Tustin, CA
    1996 5 Lug Mini
    I have a five lug did a fab tech spindle lift with a day star spacer in front and im runnig 235/75/15. I did not lose significant power.
  16. Jun 24, 2011 at 6:46 PM
    NoLimits
    NoLimits Member
    Barry
    Tulsa
    Black Longbed 4x4
