2wd lockers? or limited slip?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cheffboy3030, May 11, 2010.
  1. May 11, 2010 at 11:27 PM
    cheffboy3030
    cheffboy3030 [OP] wheelinAZ
    Richie
    Tempe, Arizona
    01 2.4L 2wd standard
    K&N intake, MAGNAFLOW exhaust, PROCOMP es3000 shocks, 1.5" front coil spacers, BFG KM2 mud tires, black UNIQUE 297 off road wheels, modified front bumper, PROCOMP 55 fluted lights, aftermarket tow hooks, BLACKED OUT everything, ALPINE deck, JL AUDIO sub
    I have a 2wd '01 reg. Cab 4 cyl. I want better performance off road and am interested in lockers or even limited slip. Haven't done much research yet.. How much work is involved in each? And what brands or types would work best? Anyone done this to their tacoma already? Replies are much appreciated
  2. May 11, 2010 at 11:38 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
  3. May 11, 2010 at 11:49 PM
    kumaWRX
    kumaWRX Well-Known Member
    Jase
    Oahu, Hawaii
    04 Prerunner TRD Offroad
    SAW 2.0 Coilovers, Wheeler's 3-leaf AAL, Toytec 1" lift shackles, Bilstein 5100 rear shocks, aFE Stg. 2 intake, Doug Thorley headers, Magnaflow muffler, 16x8 ProComp 7089 wheels, Toyo Open Country A/T tires, Pamalu bedliner, Bakflip G2 bedcover
    Mine already has the diff locker so I don't know about installation but if I didn't have it, I would def. go w/ a locker for offroad, I wouldn't go offroad w/o it if your 2WD like me. From what I've seen, I would get the ARB air locker.
  4. May 11, 2010 at 11:49 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    ARB Air Lockers are the shit...but pricey
    You should get a full time so you can engage it when you want...LSD is worthless IMO
  5. May 11, 2010 at 11:50 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
  6. May 12, 2010 at 10:42 AM
    HusqyRider
    HusqyRider Well-Known Member
    Adam
    La Mirada, CA
    01 Tacoma Prerunner SR5
    Bilsteins, HD Bakflip G2, Popnlock
    They require special tools to install, and if you aren't wrench savvy (read "very good") I would recommend getting them done by an expert.
    1. Limited Slip: Eaton/Detroit True Trac is your best option. No clutch plates to wear out (worm gear driven). uses regular diff oil. ~$500 (unit only)
    2. Drop in "lunch box" locker: Aussie, Lock-rite. Both proven traction devices but will break easier and they click or bang around turns. Powertrax No Slip also an option. ~$250-$350
    3. Full Locker: Auto (Detroit Locker) or Selectable (ARB). Both are expensive and the ARB needs a compressor to run it. The Detroit will click and bang on road, while the ARB will make no noise. ~$750-$850
    Do a search on each of these for more info. I have ARBs in my jeep and they are amazing, and I will most likely get a True Trac for my truck.
  7. May 12, 2010 at 10:44 AM
    HusqyRider
    Adam
    La Mirada, CA
    Depends on the unit. Have you driven non-factory LSDs?
