2wd LOW
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trapper6speed, Nov 25, 2010.
  1. Nov 25, 2010 at 2:25 PM
    Trapper6speed
    Trapper6speed [OP] Hacksaw engineer
    Stock
    Does anyone have the wiring diagram so I can put in a switch to engauge 2wd low, so i can back up a heavy load? I have 255/75/17s on my truck and there just a little to tall for the 3.73 gears. I would love to regear the truck but If I can flip a switch instead that would be much easier.
  2. Nov 25, 2010 at 5:28 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Bump, interesting question.
  3. Nov 25, 2010 at 5:30 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Never seen it done on a 2nd gen. You basically need to put a switch inline with the wire that tells the hubs to lock.
  4. Nov 25, 2010 at 5:32 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Would you not then be in 4WD ?
  5. Nov 25, 2010 at 5:36 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    If the switch is open, the hubs don't lock and you are effectively in 2wd. The front drivetrain is still spinning but there is no power getting to the wheels.
  6. Nov 25, 2010 at 5:36 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I've been wanting to do this also, but it looks a bit involved. I don't think the transfer case will shift into low range until it sees that the front diff is engaged. Maybe someone knows for sure, but it seems like there is a position sensor for the front diff actuator.
  7. Nov 25, 2010 at 5:37 PM
    OZ-T
    Peter North
    British Columbia
    What is the advantage to having the hubs locked and not driving ?
    Am I just dumb ? haha
  8. Nov 25, 2010 at 5:38 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah I think the 2nd gen system is a bit more complicated so it would probably be a lot of work.
    for anyone interested, this is a write up on doing this to a first gen.
    http://www.ttora.com/forum/showthread.php?t=106859&highlight=2low
  9. Nov 25, 2010 at 5:39 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    The OP basically wants the low gear ratio without the dissadvantages of being in 4wd (binding and breaking parts when turning on pavement.)
  10. Nov 25, 2010 at 5:40 PM
    joes06tacoma
    Joe
    Central Coast, CA
    What about wiring a switch to cut power to the front diff actuator and also send a signal to the 4wd computer showing that the front diff is engaged? There may also be a specific sequence of events that the 4wd computer is looking for also?
    Manual hubs would take care of the problem. Has anyone seen it done on a second gen?
  11. Nov 25, 2010 at 5:41 PM
    OZ-T
    Peter North
    British Columbia
    Gotcha , thanks Steven
    Thanks for not taking the chance to say , " Yes OZ , as a matter of fact you are dumb . "
    haha :D
  12. Nov 25, 2010 at 5:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    lol, im too nice:D
  13. Nov 25, 2010 at 5:44 PM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.ncttora.com/fsm/05+/data/ileaf/06toyewd/06toypdf/ewd/2006/tacoma/h/em01d28.pdf
    Wiring diagram
    It's obvious that the computer knows what position the front diff actuator is in. The question is does it care? It will set off alarms if you try and shift the transfer case above 50 mph, and it won't shift into 4lo unless the clutch is pressed in, seems like maybe it would refuse to go into low range if the front axle was not engaged. Who wants to be the guinea pig?
  14. Nov 25, 2010 at 5:52 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    :popcorn: I would love to do this. I've pulled my front driveshaft and put it in 4lo. It was fun but it would be very useful at the boat ramp and putting the boat away.
  15. Nov 25, 2010 at 5:55 PM
    Jason'sLawnCare
    You have ADD? That makes so much sense now.
  16. Nov 25, 2010 at 5:56 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I miss having a lever shift transfer case and manual hubs. If you want 2lo, you just shift the case into 4lo and don't bother getting out to lock the hubs. Things were simpler with my old 1986 Toyota! :(
  17. Nov 25, 2010 at 5:59 PM
    Jason'sLawnCare
    Yes but now you have 236hp :woot: but I agree and am all for simplicity.
    :rofl: Sorry.
  18. Nov 25, 2010 at 6:13 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    I want manual hubs, 4lo with out locking hubs = 2lo
  19. Nov 25, 2010 at 6:24 PM
    Jason'sLawnCare
  20. Nov 25, 2010 at 6:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    No, that's quite all right! I spend most of my time on the highway with this truck, and I love setting the cruise on 75 and cranking the AC. The 1986 had 95hp, no AC and it topped out at 74MPH with 31 inch tires! But it did have 2lo for backing up steep driveways.:D
