2wd LT vs 4x4
Discussion in 'Long Travel Suspension' started by dodgers2036, Feb 11, 2015.
  1. Feb 11, 2015 at 7:42 PM
    dodgers2036
    dodgers2036 [OP] Member
    Miguel
    805
    Future Taco Owner
    Hey guys I'm new here to the forums and I know this has probably been asked a 1000 times but I want your opinion. Would you rather have a long travel 2wd or a somewhat built 4x4. I currently have an 1981 Chevy Blazer 4x4 and am looking to get a tacoma in the near future but can't decide on what set up to go with once I get one. I mostly hit the mud holes with the deepest being about 3 feet and pismo. So far my blazer has done all this in 2wd but I didn't go very hard at pismo due to not having someone to pull me out if I did get stuck.
  2. Feb 11, 2015 at 7:55 PM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    So just go 4x4 with some slight mods instead of a LT 2wd?
  3. Feb 11, 2015 at 8:15 PM
    YotaX
    YotaX Member
    1999 SR5 Xtra Cab
    Bilstein 5100's, OME 881, Icon 1.5 AAL w/o overload
    If your mostly hitting mud you probably want 4x4.
  4. Feb 11, 2015 at 8:30 PM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    It's the occasional mud after a rainstorm but mostly pismo and dry, hard dirt.
  5. Feb 11, 2015 at 8:36 PM
    YotaX
    YotaX Member
    1999 SR5 Xtra Cab
  6. Feb 12, 2015 at 1:32 AM
    troyboy162
    troyboy162 Well-Known Member
    troy
    If you never use 4x4 then you're fine. If you turn it on once in awhile then you would surely miss not having it. You are a candidate for a 4x4 long travel I'd guess. Its a compromise of front end travel, but you can do alot with 13-14"(toyota travel, I dont know blazers) from a 4x4 if its properly valved. Add in a bypass and you can go even faster.
    If you want to go as fast as possible then you'll want the 2wd 16-18" (toyota) of travel and the roll cage/engine cage/solid mounts that go along with that to use it to its potential.
  7. Feb 12, 2015 at 9:05 AM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    Problem is I'll only be able to afford either a 2wd long travel or a 4x4 with some suspension mods.
  8. Feb 12, 2015 at 9:10 AM
    ATLien
    ATLien Well-Known Member
    Portland
    2013 DCSB SR5
    Money Pit
    Sounds like a midtravel 4x4 is in your future...
  9. Feb 12, 2015 at 9:11 AM
    Manwithoutaplan
    ID
    4x4 all day everyday.
  10. Feb 12, 2015 at 9:14 AM
    TacoMAUI95
    TacoMAUI95 Well-Known Member
    Maui,HI
    17DCLB TRDOR MGM. Replaced 2014 DCSB TRDOR
    Nothing yet. Old truck had the works.
    If you have to go a little slower and be able to go everywhere and anywhere. Or be able to fly across the flat desert and look at a small hill and know you can't make it. Id say go 4x4. So many more possibilities.
  11. Feb 12, 2015 at 1:13 PM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    Thats what i was thinking.. icon stage 3 or the build your own mid travel from DSM?
  12. Feb 12, 2015 at 1:24 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I think you'll be happiest sticking with the 4x4
  13. Feb 12, 2015 at 1:24 PM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    the deepest i've seen in my blazer is about 3 feet. I'll mostly be hitting pismo once i get my tacoma
  14. Feb 12, 2015 at 1:28 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    There isn't much you CANT get out of at Pismo, with a 4x4. Unless you rolla bead, like I've done on a few occasions. :anonymous:
  15. Feb 12, 2015 at 1:39 PM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    Cleanup does suck but it's fun while it lasts. the mud hole is only like 10 feet long so i just go through then turn around and come back a couple times.
  16. Feb 12, 2015 at 1:40 PM
    dodgers2036
    Miguel
    805
    Future Taco Owner
    I haven't gone too hard at pismo due to being alone but in all the spots i went through i was fine in 2wd
  17. Feb 24, 2015 at 1:29 PM
    reece54
    reece54 Well-Known Member
    Reece
    91765
    16' 4x4 trd off-road
    I would go 4x4 only because there will be time when you hit a sand pile and get stuck and won't have 4wd to help you out. But it's your personal preference if you want more travel I would go with 2wd. I'm pushing 15-16 in of travel with my 4wd lt
