2WD off-roading?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TEX357, Jul 3, 2009.
  1. Jul 3, 2009 at 11:22 AM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Well my truck is a 2wd and I keep getting stuck every time I go out in some mud. Is there a skill to this? 2 out of 2 times Ive tried to go out muding I got stuck. Can anyone tell me what they do or help me out? Also I'm going to the beach in a couple of days and going to take my truck. What do you all recommend i deflate my tires at for the moist sand?
  2. Jul 3, 2009 at 11:24 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yes airing down for sand is nearly crucial....More so for a 2WD cause if you get stuck you are going to need someone to tug you out.
    And wheeling a 2WD is a skill. I know nothing about it cause I've always had 4x4...I'm sure someone will be able to help you tho.
  3. Jul 3, 2009 at 11:25 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    I've never gotten stuck in mud. Only sand. I must be a natural. :D
  4. Jul 3, 2009 at 11:26 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Oh yes, air down in the sand. I run at about 12 PSI in the sand on all tires.
  5. Jul 3, 2009 at 11:26 AM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    I'm guessing its because i have Mudsss so they digg pretty fucking quick!!!
  6. Jul 3, 2009 at 11:28 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    You would think muds would get through the mud easier. :laugh:
  7. Jul 3, 2009 at 11:29 AM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    i dont see how your getting stuck with KM2's either.... I am running stock dunflops and came close a few times but havnt been stuck yet. just keep momentum up and try not to stop in the mud. Look for the stuff thats not as deep.
  8. Jul 3, 2009 at 11:30 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Momentum is huge! Don't go too fast, but fast enough. :D
  9. Jul 3, 2009 at 11:31 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    12 is pretty low imo...
    I don't run less than about 17 unless I have an air supply for immediate air up once I'm done. If you lose a bead-it sucks- and the lower the pressure goes...The more likely it is to happen if you hit and rock or bumps on your way to get air...but again-all that is my 4x4
  10. Jul 3, 2009 at 11:32 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Maybe it was 15.
    Correction, it was 15. :)
    But yes I have an air compressor and I fill the tires back up when it's time to hit the road. :)
  11. Jul 3, 2009 at 11:32 AM
    rmb_crew
    and if you air down low. dont make sharp turns. you will slide right off that bead and your done.
  12. Jul 3, 2009 at 11:40 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    GO VERY VERY FAST!!!!! :devil:
  13. Jul 3, 2009 at 11:54 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    It is way more fun to play in 2wd. Mudding is a skill in general especially here where I live, we often times don't have a bottom. Keep the speed up without don't dog it ease into the speed. When moving forward gets slow and you think you will get stuck start turning your wheel not a whole bunch just enough to get the rear wheels biting some new ground not just following the front wheel.
  14. Jul 3, 2009 at 11:58 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    in my opinion prerunning is the best kind!! more challenge.... i guess haha but i 2wd and ive only gotten stuck twice..... once in the desert and the other time i almost got out but somone pulled me out
    and with 2wd you have to mob thrugh mud supe fast or you will get stuck
  15. Jul 3, 2009 at 12:02 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    i know all about momentum....... and running into bushes.... and trees
  16. Jul 3, 2009 at 12:03 PM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
    so is the the new avatar everyone is using?
  17. Jul 3, 2009 at 12:24 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    Haul ass!!!!!!!!!!!!!! Lol
  18. Jul 3, 2009 at 12:27 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Not sure what your asking but here goes.
    That is Bill a TW member and his wife Michelle, she has cancer and we want to show them that we are thinking and praying for them. Click the link in my sig.
  19. Jul 3, 2009 at 12:47 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    i haven't gotten stuck w/ my 2wd taco yet. I did all the time w/ my 4wd , z71. Approach things logically, with a little more speed that normal, know what the hole contains (no secret monster ruts). I used to just crawl through everything like i do on my jeep (has kick ass tires and 4wd), but with the taco, you gotta hit the "TRUSTWORTHY" mud hole about 5-10 mph. more like 10 though.
  20. Jul 3, 2009 at 1:18 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I really don't do mudding, but I do like trails. With my Prerunner, I haven't really gotten stuck YET. :D
