2wd prerunner lift question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05yota, Dec 30, 2010.
  1. Dec 30, 2010 at 2:09 PM
    05yota
    05yota [OP] Well-Known Member
    Beaufort SC
    05 Dbl Cab Long Bed
    Alpine IVA-W205 Double din TV, 10in Memphis shallow mount sub, Rockford Amp, 23in Akuza Bounce Rims!!!
    ok so i have decided to lift my 05 tacoma dbl cab long bed and get rid of the big rims look... i have sat on here for the past 3 hrs and researched the site about spacers vs the 5100s so on and so forth... to get started its gonna be for looks i like the feel of a truck that sits up higher so i am looking for the right choice that wont break the bank but will last.. i was hell bent on the toytec 3" spacer but then i saw the 3" that had new coils with a spacer whats the difference??? then i saw alot guys on here running the 5100s??? i am so confused right now... all i want is my truck is about three inches of lift and to be able to put a thicker tire and still maintain a decent ride quality??? PLEASE HELP!!!!
  2. Dec 30, 2010 at 2:16 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    if you are willing to spend a little bit of money i would look into a spindle lift. they are 3.5" to 4" but it is a front lift only. they keep the suspension geometry the same, so you will maintain stock ride comfort. if i was going to lift again i would do it right the first time and not have to go back and redue it.
    http://www.camburg.com/toyota/05-09-tacoma/4-performance-lift-spindles/
    for the rear i would do block w/ aal or just go ahead and get a whole new leaf pack allpro 3in leaf pack maybe.
  3. Dec 30, 2010 at 2:17 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Get camburg spindles, and get 4" of lift and you can keep your stock suspension up front.
  4. Dec 30, 2010 at 2:19 PM
    senor taco
    Monterey Bay, Ca
    And lift the rear with all pro leaf pack.
  5. Dec 30, 2010 at 2:43 PM
    05yota
    Beaufort SC
    05 Dbl Cab Long Bed
    thanks for the current responses but i am never gonna go offroad with this truck meaning like mudding or trail romping and its only a two wheel drive is there another route that is a little cheaper?
  6. Dec 30, 2010 at 3:04 PM
    senor taco
    Monterey Bay, Ca
    I have bilstien 5100's with a 2" AAL it was under 450$
  7. Jan 11, 2011 at 7:10 AM
    T.J.
    T.J. Taco Jockey
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    Century Truck Topper, custom made "Batman" center caps, satoshi mod (Thanks tons, TY!), Hella 500 grille lights, painted radio, climate control, and radio surround panels, painted rear bumper
    Wondered about this.... nothing else is needed up front, just throw on the spindles and all is good?
  8. Jan 11, 2011 at 7:11 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    yup
  9. Jan 11, 2011 at 7:24 AM
    T.J.
    T.J. Taco Jockey
    TJ
    North Port, FL
    05 PreRunner SR5 V6
    hmmm.... in this case it would seem to be the better option for the PreRunners. Less components to deal with. Is it a true 4" lift up front if going with a 4" lift spindle?
  10. Jan 11, 2011 at 7:29 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    he said he didnt wanna brake the bank so spindles are out....
    get the billy's and call it a day.
  11. Jan 11, 2011 at 7:33 AM
    08pretaco
    Oliver
    az
    The ONLY way to get 4" is with spindles or RCD lift for 4.5". They give you 4" and a wider track width up front as well, kinda the first step in the prerunner look before LT. Yes they cost 1k but I have never spent so much and been so happy! By far the best money spent on my truck. If I were you, which I was, keep the truck stock and save up for the spindles and do that the first time. saving on lunch money by taking it to work could get you the spindles in a couple months.
