2wd prerunner!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calixto25, Sep 20, 2013.
  1. Sep 20, 2013 at 1:43 AM
    calixto25
    calixto25 [OP] Well-Known Member
    Arizona
    TRD sport
    Hids, billet grille, headlights, fog lights, k&n intake, throttle body spacer, led taillights, led bulb conversion.
    I have a 2005 tacoma sport 2wd v6. I want to put long travel on the truck soon and basically be able to take it to pismo beach and the dunes. But I want to make sure I am not going to be axle deep stuck in sand all the time lol. I was thinking if I had a locking rear diff with some mud terrain tires aired down would work or am I going to be getting pulled out all day haha.
  2. Sep 20, 2013 at 1:46 AM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    You will be fine as long as you keep the throttle down through the soft sand and make sure you have buddies with 4wd
  3. Sep 20, 2013 at 1:49 AM
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    I'm interested to see what people say about this. I think you'd be fine as long as you are smart. Crossing that "river" into Pismo could be harry though...
    You may want to carry some traction pads like these http://www.4wheelparts.com/Winches-Winch-Accessories/Bushranger-Sand-Tracks.aspx?t_c=18&t_s=190&t_pt=9592&t_pn=ARB54X07
    Also, keep a tow strap in your truck! If you get stuck, people will be more likely to help if you already have the tow strap connected.
    I have a PreRunner and have been off road many times and only gotten stuck once... I got out by putting a carpet sample under my wheel.. Air Down your tires...
    Last time in the desert, I found a loose sandy trail and my new BFG's preformed great!
  4. Sep 20, 2013 at 1:52 AM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    do not afraid
    don't forget to air down~
  5. Sep 20, 2013 at 1:55 AM
    jackrules
    Jack
    San Diego
    I've not seen this done, but you may think about getting a cheap pair of rims and putting a paddle tire on it?!?!?! When you get there, you could switch out your rear tires and then you would really have something! I wouldn't use a paddle tire with the diff locked though. Just a thought.. I'm sure mud-terrains will do fine.
  6. Sep 20, 2013 at 1:58 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Tacos are too slow for paddles. Some AT's or MT's and air down...don't stop in the soft stuff, just keep the momentum going.
  7. Sep 20, 2013 at 3:08 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Mud terrains might have too aggressive of tread for sand. You want to float, not dig in to find traction.
    Momentum is key as everyone said and coast to a stop. Avoid heavy braking. Drop down to around 12 PSI. You may need to let out more air depending on the sand.
  8. Sep 20, 2013 at 6:13 AM
    calixto25
    Arizona
    TRD sport
    thanks for all the info on the topic. I am still not sure what i want to do. I really want to be able to go and just wramp if I wanted to and not have to worry about it. I guess I might have to trade the 2wd in for a 4x4 :D
