2wd to 4wd failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ajsabra, Sep 14, 2017.
  1. Sep 14, 2017 at 9:46 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What happens with ADD when a front locker is installed?
    MOC221_ likes this.
  2. Sep 14, 2017 at 9:48 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    For 4WD to engage, it's not just the transfer case, the actuator at the front diff also has to be able to engage. I'd say it's probably a pretty hard argument to make that when installing the locker, they didn't touch that front actuator and that the fault still lies with Toyota.
    Roland79 likes this.
  3. Sep 14, 2017 at 9:51 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Unfortunately that seems to be the case. It should be toyota should have to prove it wasn't the locker, but it's their warranty and we have to play that game until we prove it otherwise.
    hiPSI[QUOTED] and Roland79 like this.
  4. Sep 14, 2017 at 9:53 AM
    ak49watson
    ak49watson Cuts Right
    Alaska
    2017 Barcelona Red Tacoma TRDOR DCB 6MT Tech
    I've seen this type of thing a lot, especially when I had a Camaro. If you're going to modify a vehicle, don't expect it be warrantied when it fails. We all know what the moss act says, how often does it really matter. Pay to play, or remove mods for warranty work.
    They probably don't look at it as individual components. All they see is the 4wd -system- is no longer stock. I don't blame them for not touching it.
    hiPSI and Roland79 like this.
  5. Sep 14, 2017 at 10:00 AM
    ajsabra
    ajsabra [OP] Fully locked 3rd gen
    Sin city
    2016 Tacoma DCSB 4X4 Manual
    Front suspension : Extended travel Kings with Total Chaos UCAS Rear suspension : Deaver progressive AAL w/out overload & Kings Rims : SCS SR8 17" Tires : Bfg KO2s 285/70/R17 ARB Compressor ARB Lockers front and rear with 4.88 gears Nitro 4.88 Gears TRD Pro Grill, and fogs Headlight BHLM Rigid Radiance 32 stealth mounted.
    Hard to remove ARB locker for warranty work lol, but I get you.
  6. Sep 14, 2017 at 10:05 AM
    ak49watson
    Alaska
    Not really. I'd have it done in a few hours. Where's your stock carrier?
  7. Sep 14, 2017 at 10:06 AM
    ajsabra
    Sin city
    in the truck....
  8. Sep 14, 2017 at 10:09 AM
    Jeff1795
    Jeff1795 Well-Known Member
    Panama City FL
    LT 2017 TRD Sport 4x4 Access Cab 6-Speed
    I had the same problem and it was a loose abs sensor connector. And then I had a similar problem except I couldn't engage 4wd at all! And it was a abs sensor wire that snapped in half!
    Clay7160 likes this.
  9. Sep 14, 2017 at 10:19 AM
    ajsabra
    Sin city
    Good to know. As of right now, I'm taking my truck from them, and having my locker installer diagnose the problem.
  10. Sep 14, 2017 at 10:23 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Truth
    dYL0n[QUOTED] likes this.
  11. Sep 14, 2017 at 11:25 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yup for 4wd to show its all the way in, ADD AND tcase have to report back that they are fully in. Front locker means removal and disassembly of full front clamshell diff housing and subsequently the ADD system.... not saying that the installer caused the problem... but its going to be a very hard case with toyota as you / your installer was the last person to touch and "modify" the part.
  12. Sep 14, 2017 at 11:35 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    That is how it's supposed to work. The way the law is written the warrantor needs to demonstrate that the failure was caused by the aftermarket part. Key word is "demonstrate", not just look at it and say hey we THINK that thing you put on here broke it. Real world it's not that easy unfortunately.
    NMroamer likes this.
  13. Sep 14, 2017 at 11:43 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I used the word "think" as a catch all verb. There is no specific way it works as every case is different. And all that stuff is already in the owner's manual anyway. They know the rules. There are also limitations too. Let's say you put different offset wheels on your truck, and you had a front bearing failure at 50K miles. The dealer has two choices: Approve the warranty as a bad bearing or deny warranty saying the high offset wheels contributed to bearing failure. Now, prove it. Well, I'm pretty sure that the dealership does not have the expertise to prove it, the owner does not have the expertise to disprove it and if you put it in the hands of someone like me, I will tell you there is not enough data to either prove or disprove that, in this one specific case, high offset wheels contributed to premature bearing failure! Too many variables. So now what... it goes to the dealer to make a judgement call.
  14. Sep 14, 2017 at 11:46 AM
    James_Bond
    James_Bond Well-Known Member
    Southern California
    '16 TRD Sport DCLB
    All stock
    Hell adding 33' tires void your power trains warranty if they really wanted to give you a hard time.
    hiPSI likes this.
  15. Sep 14, 2017 at 11:52 AM
    #35
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    That doesn't seem unreasonable to me.
    If it's a warranty issue they will fix it under warranty. If it's not, you'll pay them for their time troubleshooting like you would with any other non-warranty issue.
    Am I missing something?
    If you are sure it's not the front locker that's causing the problem then you should be fine. If you think it could be the front locker go to the guy that installed it and say wtf.
    hiPSI and Lt. Dangle like this.
  16. Sep 14, 2017 at 11:58 AM
    #36
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    An ARB replaces your stock carrier...so no your stock carrier is not in the truck.
    ak49watson[QUOTED] likes this.
  17. Sep 14, 2017 at 2:59 PM
    #37
    ajsabra
    Sin city
    I pay to diagnose regardless.
  18. Sep 14, 2017 at 2:59 PM
    #38
    ajsabra
    Sin city
    Its in the bed of the truck literally....
    friendlywithbears and Roland79 like this.
  19. Sep 14, 2017 at 3:03 PM
    #39
    ajsabra
    Sin city
    What would you do about the hole thats drilled for the air line? Can't hide it from toyota.
  20. Sep 14, 2017 at 3:15 PM
    #40
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Honest question, why do you say that? And do you mean to say you would test it after pulling the shaft while the truck is in motion?
