2wd truck, install 4wd leaf springs HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by grancpe, Dec 9, 2011.
  1. Dec 9, 2011 at 4:40 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    I have a 96 2wd tacoma and purchased Dorman leaf springs for a 4wd. Is the shackle different or the bushings in the rear of the leaf. Do I need to have the 4wd bushings pressed out and install the 2 separate bushings like the original leaf or can I buy a different shackle. Any help is appriciated.
  2. Dec 9, 2011 at 4:42 PM
    98tacoma27
    Ben
    Not Beech Creek
    5 lug 2wd or Pre-runner 2wd?
  3. Dec 9, 2011 at 4:43 PM
    98tacoma27
    Ben
    Not Beech Creek
  4. Dec 9, 2011 at 4:46 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    There there ben. It's ok. Normally you are the quickest on the draw.
    But even the sun shines on a dog's ass from time to time. :)
  5. Dec 9, 2011 at 4:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    Don't forget I can make you all go away..............permanently. :cool:
  6. Dec 9, 2011 at 4:50 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    It is 5 lug. The springs side by side seem to be the same but the rear bushing is the same as the front on the new Dorman spring and the shackle will not fir through the steel insert where as the original spring had 2 all rubber bushing that fit fine.
  7. Dec 9, 2011 at 5:05 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    I also have a 96 tacoma 4wd but cant tell if the shackles are the same or different. They seem the same but the inside diameter may be different. I would rather just purchase the correct shackles if you guys think that would solve my problem or do the Dorman springs just suck.
  8. Dec 9, 2011 at 5:07 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    Thanks
  9. Dec 9, 2011 at 6:03 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Are you trying to lift it? Lower it? Just replace old springs?
    5 lugs are sprung-under, which means the leaves are attached at the bottom of the axle. 4x4s are sprung-over, which means the leaves are attached at the top of the axle. 4x4 leaves actually have less arch, so installing them on a 5 lug will drop it, which may be exactly what you are trying to do. As for the shackles, I have no idea. I'm assuming they're probably different.
  10. Dec 9, 2011 at 6:08 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    Just trying to replace springs. I can get the 4wd ones under the axle fine but the shackle will not fit the spring. Need to know if I need a different shackle or replace the rear spring bushing to the 2 separate rubber ones like the 2wd originals springs were.
  11. Dec 9, 2011 at 6:22 PM
    MowTaco
    Kansas
    Hmm. I have no idea then.
  12. Dec 9, 2011 at 6:25 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    Thanks anyway. Maybe I will try a new post names shackle help.
  13. Dec 10, 2011 at 4:49 PM
    grancpe
    grancpe [OP] Member
    Florida
    96 Tacoma
    Got it figured out. Thank all of you for your help!
  14. Aug 30, 2016 at 9:31 PM
    illini_Taco_Guy
    illini_Taco_Guy Member
    Owner of many tacos
    blue chew
    What was the result????
    I am in the exact same boat right now. I have 4wd shackles and the Dorman springs on the way.
    Was the truck about the same with the 4wd leaves??
    Really wondering how it will turn out.
