2wd vs 4wd Short Shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nukewater, Oct 6, 2009.
  1. Oct 6, 2009 at 7:01 AM
    Nukewater
    Nukewater [OP] Well-Known Member
    Adam
    Saskatchewan
    Dangit.
    Can I use the short shift kit from my X-Runner in a new 4x4 DC?
  2. Oct 6, 2009 at 7:06 AM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    ok i really wanted the B&M S/S really badly but when I saw that it was meant for the 4x2 (XR and Prerunners) only I hesitated on purchasing it cause I wondered if it was possible to use the same shifter since the transmission is exactly the same...only difference is the 4x4 transfer case...
    I opted on purchasing the TRD S/S for the 4x4s...about a month of installing I saw a member on here install the B&M S/S into his 4x4 taco without any problems....so from that I'm sure its possible...you shouldn't have any problems just don't drive it if there is any binding between the shifter and transmission...
    good luck and keep us posted on which S/S you end up going with bro...
  3. Oct 7, 2009 at 12:29 PM
    Nukewater
    Adam
    Saskatchewan
  4. Oct 7, 2009 at 12:33 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Try it and find out. You will know immediately.
