2WD VS Prerunner std and options
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nobra25, Jan 11, 2023.
  1. Jan 11, 2023 at 11:42 AM
    nobra25
    nobra25 [OP] Member
    Smitty
    I'm interested in knowing the OEM differences between the an 2wd and the prerunner. I'm aware that there both 2wd, and the prerunner also has a small lift. but I cant seem to find other info on the differences, eg 4wd frame? suspension? etc.
    thanks
    Bryce
    HondaGM likes this.
  2. Jan 11, 2023 at 11:45 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    burrito782, Taco 422 and nobra25[OP] like this.
  3. Jan 11, 2023 at 12:00 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The PreRunner has better suspension and driveline components. It’s as close as you can get to a 4WD, without actually getting a 4WD.
    Better suspension
    Better hubs and bearings
    Better differential w/different gears.
    Better brakes…….
    burrito782, HondaGM and nobra25[OP] like this.
  4. Jan 11, 2023 at 12:05 PM
    nobra25
    nobra25 [OP] Member
    Smitty
    if that's the case then the payloads would be different too, right?
    I'm looking to put a pop-up camper on a 2wd platform that weighs 300 to 500 lbs as well as gear. maybe 1000 lbs total.
    HondaGM likes this.
  5. Jan 11, 2023 at 12:08 PM
    anthemAnathema
    anthemAnathema Well-Known Member
    2013 4.0 6MT Access Cab TRD Offroad
    Elka 2.5 w/ DSC RCI Skids AP Expedition Leafs Leer 180
    Why 2wd? 4wd is worth it's weight in gold when you need it, which quite often happens when you think you won't.
    nobra25[QUOTED][OP] and HondaGM like this.
  6. Jan 11, 2023 at 12:13 PM
    nobra25
    nobra25 [OP] Member
    Smitty
    I would be spending more time on paved or unpaved roads. I'm retiring soon and love to drive and camp instead of motels.
    FYI: it will have 2.7l and m/trans
    Steves104x4 likes this.
  7. Jan 11, 2023 at 12:22 PM
    TnShooter
    Deogee
    STOCK
    In this case, I would %100 recommend a PreRunner.
    I had a 2.7 manual trans PreRunner before I bought my current 4WD. Great driving truck. The 2.7 doesn’t get a lot better mpg. So don’t count off a 6cyl.
    I went 4WD because I tow a lawn equipment trailer quite often. I needed 4WD for wet yards and the extra power from the 6 cyl was MUCH better.
    I will say, the 2.7 w/5 spd was such an easy truck to drive.
  8. Jan 11, 2023 at 12:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pre-runner will have 6 lug axles and 4 piston brake calipers on the front, tow rating isn't much different on the 4 cyl between a 5 lug and 6 lug but you would have slightly better stopping power on a 6 lug.
    burrito782, nobra25[OP] and TnShooter like this.
  9. Jan 11, 2023 at 12:35 PM
    nobra25
    nobra25 [OP] Member
    Smitty
    WOW, this is all great info that would've taken hours/days to find.
    Dm93 and TnShooter like this.
  10. Jan 11, 2023 at 7:33 PM
    oneikr
    oneikr Well-Known Member
    2024 GMC Sierra 1500 Denali
    Don’t forget increased ground clearance. It sounds like you’re interested in my truck. 2010 Prerunner AC 2.7L 5MT with 160k. Super reliable for 13 years and still fun to drive. Best of luck finding what you’re looking for.
    nobra25[OP] and Dm93 like this.
  11. Jan 11, 2023 at 7:45 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
  12. Jan 12, 2023 at 10:19 AM
    nobra25
    nobra25 [OP] Member
    Smitty
    nice truck and your right, it is what I'm looking even the color! I'm looking at one here locally.
  13. Jan 12, 2023 at 11:49 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    A Prerunner is a 4WD truck without the 4WD drivetrain. Mine has the tow package and rear locker. Perfect for driving off road, but not "four wheeling".
    nobra25[OP] likes this.
  14. Jan 12, 2023 at 1:31 PM
    nobra25
    nobra25 [OP] Member
    Smitty
    what exactly does the Tacoma tow package consist of?
  15. Jan 12, 2023 at 1:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Note the tow package is only available on V6 trucks.
    Towing package includes:
    27F battery (non Tow Package has 24F)
    130 Amp Alternator
    Engine Oil Cooler
    Auxiliary Transmission Cooler (A/T only)
    Class IV Receiver Hitch
    7 Pin Trailer Connector with Trailer Brake Control Harness in Cab (Brake controller not included)
    2012 and up models added Trailer Sway Control Programming in the VSC System
    Bumps the tow rating from about 3500# to around 6400# when using trailer brakes.
  16. Jan 12, 2023 at 6:13 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    The following might help better illustrate the front end & suspension differences between the 2WD 5 lug and the 2WD 6 lug / Prerunner. You'll notice the differences in their shock towers, control arms/mounts, spindle lengths, shock/coil lengths, etc.
    2WD 5 Lug
    Pictures: https://www.tacomaworld.com/threads...toyota-never-made.690223/page-2#post-24593957
    Service Manual Diagram: https://www.tacomaworld.com/threads...toyota-never-made.690223/page-2#post-24593951
    2WD 6 Lug / Prerunner
    Pictures: https://www.tacomaworld.com/threads...toyota-never-made.690223/page-2#post-24593949
    Service Manual Diagram: https://www.tacomaworld.com/threads...toyota-never-made.690223/page-2#post-24593946
  17. Jan 13, 2023 at 7:16 AM
    GorgeRunner
    2005 PreRunner
    Sorry, forgot to mention I had the V6. I don't tow anything but I am happy to have this stuff, especially the coolers. Hauls my 30 lb mountain bike easily.
  18. Jan 13, 2023 at 9:05 AM
    nobra25
    nobra25 [OP] Member
    Smitty
    thanks for the pics and technical info. very resourceful, a huge difference, it also explains the price differences.
    burrito782[QUOTED] likes this.
  19. Jan 13, 2023 at 1:18 PM
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Not sure if it's Pre-Runner standard equipment or a TRD Sport package upgrade, but my truck also has a factory inverter with a plug-in in the bed. Super useful when I go camping. Might be something you want to keep your eye out for when shopping
    Also (and again), not sure if this is a Pre-Runner thing or Turd Sport pack, but I also have an LSD that's proven dang nice in wet/slick stuff
  20. Jan 13, 2023 at 1:21 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The inverter I believe is standard on TRD Sport and TRD OffRoad trucks and optional on SR5 trucks.
