2x to 4x conversion for my 2nd gen (14)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokrys, Aug 24, 2016.
  1. Aug 25, 2016 at 1:02 AM
    #41
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    My friend @luka has also done a prerunner to 4x4 conversion.
  2. Aug 25, 2016 at 1:04 AM
    #42
    tacokrys
    tacokrys [OP] Well-Known Member
    krystian
    '14 tacoma full cab trd
    leveling kit, bfgoodrich all terrain ko2, 17in pro comp wheels, bp fabricating skid plate
    Ok, sweet. I guess my next step is researching and acquiring the parts
  3. Aug 25, 2016 at 2:16 AM
    #43
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    To help source parts http://www.car-part.com/
    I'm picking up parts Monday, got a good deel on all 4Runner parts from salvage yard. Same parts as taco just cost less.
  4. Aug 25, 2016 at 2:30 AM
    #44
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    Found all my parts on www.car-parts.com.
    And with a fj case you won't need a computer to control it you just stick it in 4l,4h and go
    Biscuits and Aw9d like this.
  5. Aug 25, 2016 at 7:10 AM
    #45
    tacokrys
    krystian
    Hmm, I wonder why that is? @ahspurlock so aka I won't need that ADD system?
  6. Aug 25, 2016 at 7:15 AM
    #46
    tacokrys
    krystian
    I was looking at that same website too. Do the parts come with the seals too?
  7. Aug 25, 2016 at 7:17 AM
    #47
    ahspurlock
    Adam
    no you will still need the ADD thats what turns on the front diff but RST makes a plug and play switch for that it runs like $130 for it
  8. Aug 25, 2016 at 7:27 AM
    #48
    tacokrys
    krystian
    Righty o, I'll look into that. So I found most of the parts, only thing I can't find are the 2 front axles.
  9. Aug 25, 2016 at 7:30 AM
    #49
    ahspurlock
    Adam
    most junk yards have them for $30 a axle or just go buy new ones from a parts store
  10. Aug 25, 2016 at 7:37 AM
    #50
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Doesn't he need the Fj case from a 6 speed ? Or is that the full time 4wd one ?
  11. Aug 25, 2016 at 7:40 AM
    #51
    YamaDirtrider
    Josh
    Elizabeth CO
    Auto, and to fit it well you should do twin sticks conversion
  12. Aug 25, 2016 at 7:42 AM
    #52
    ahspurlock
    Adam
    the 6speed is full time he will need one from a auto
  13. Aug 25, 2016 at 7:43 AM
    #53
    ahspurlock
    Adam
    i dont like the twin stick to much bullshit to remember :rofl:thats why i just stayed with the stock shifter still need to put in the upper boot
  14. Aug 25, 2016 at 7:44 AM
    #54
    tacokrys
    krystian
    So its almost easier, and cheaper to use a Tacoma transfer case
  15. Aug 25, 2016 at 7:45 AM
    #55
    ahspurlock
    Adam
    to cus you will have to find a way to make it shift in and out of 4wd
  16. Aug 25, 2016 at 7:50 AM
    #56
    ahspurlock
    Adam
  17. Aug 25, 2016 at 7:53 AM
    #57
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    You can make your own ADD switch and harness. It's pretty easy. The wiring diagram is on RST. I'll post it here if you can't find it. It's just a connector, DPDT rocker switch and some wire. Do it yourself and save $100. Plus you'll get an understanding of the system in case you need to troubleshoot an issue later.
    ahspurlock likes this.
  18. Aug 25, 2016 at 8:23 AM
    #58
    jowybyo
    Joe
    Baltimore, MD
    No. It's a huge pain. I went the stock Tacoma t-case route and it sucked. I'm about to pull it out and swap to an FJ case.
    Biscuits and ahspurlock like this.
  19. Aug 25, 2016 at 8:27 AM
    #59
    bullaculla
    Da big big island!
    Manual T case all the way. I have the tacoma t case I'd sell you cheap, but shipping will be high, and you'd regret it :D
  20. Aug 25, 2016 at 8:44 AM
    #60
    jowybyo
    Joe
    Baltimore, MD
    @tacokrys where are you located. If you are really interested in doing the Tacoma t-case, I will sell you my setup.
