2x to 4x conversion for my 2nd gen (14)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokrys, Aug 24, 2016.
  1. Aug 25, 2016 at 9:32 AM
    #61
    tacokrys
    tacokrys [OP] Well-Known Member
    krystian
    '14 tacoma full cab trd
    leveling kit, bfgoodrich all terrain ko2, 17in pro comp wheels, bp fabricating skid plate
    @ahspurlock ya I took a peek. That's gold. I'm going to use that as a bible. @jowybyo I like the idea of having direct manual control, but part of me wants it to look like it came out of the factory. I've been reading stuff about not being able to take it from 2x to 4x, what controls that?
  2. Aug 25, 2016 at 9:42 AM
    #62
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    On a stock Tacoma, it would be the 4WD ECU. Basically a small micro-controller, that receives input from the 3 position dial switch to activate the front ADD system and shift the t-case in to the selected gear. It also monitors other systems including your speed to make sure it's "save" to shift into 4WD. However, the ECU is unreliable at best. My educated guess is that the ECU getting confused is the reason so many ppl have an issue shifting into and out of 4WD.
    To go this route and be purely "stock", you need to get the ECU, the wire harness, the stock switch, the dash radio surround (with the hole for the switch). You'll have a mess of wiring to figure out. It's possible with enough patience. But it will be far easier to just get an FJ case and skip all of that.
    I did something in between. I wired my own circuit to control the t-case. It uses a series of relays wired to a 3 Position dial switch. It works remarkably well. Actually, I've had a lot of issues with the ADD wiring everyone suggests and no issues with the circuit I invented for the t-case.
    Biscuits and ahspurlock like this.
  3. Aug 25, 2016 at 10:02 AM
    #63
    tacokrys
    krystian
    Hmm. Touche. So far everyone is pointing me towards the add switch, what kind of issues did you have? My buddy mentioned something about a crawl box along with the transfer case, is that what you did?
  4. Aug 25, 2016 at 10:08 AM
    #64
    jowybyo
    Joe
    Baltimore, MD
    The ADD switch is the only option if you don't use the 4WD ECU.
    I keep burning up the ADD motor. I could likely have had these problems anyway. Seems like some people do.
    I did not use a crawl box. But they are all stick shift so if you decide to use one then you should definitely use the FJ t-case since you'll be cutting a hole in your floor anyway.
    Biscuits likes this.
  5. Aug 25, 2016 at 10:47 AM
    #65
    Aw9d
    Aw9d That one guy
    Subbed. I've been hunting down parts to do this myself.
  6. Aug 25, 2016 at 10:58 AM
    #66
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    www.car-parts.com
    this is were i found the parts i needed
    Aw9d[QUOTED] likes this.
  7. Aug 25, 2016 at 11:08 AM
    #67
    Aw9d
    Aw9d That one guy
    Thank you! My issue is finding someone local that can do it for me once I get the parts.
    ahspurlock[QUOTED] likes this.
  8. Aug 25, 2016 at 11:09 AM
    #68
    ahspurlock
    Adam
    i could if you werent so far away . im getting ready to do one in 3 weeks charging $1500 to do it
  9. Aug 25, 2016 at 11:11 AM
    #69
    Aw9d
    Aw9d That one guy
    Yeah that's one hell of a drive! Time to make a full parts list and start hunting down everything I need. There are some really good guys on TW who have shops that I'm sure one could help me out.
  10. Aug 25, 2016 at 11:11 AM
    #70
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    In :popcorn:
    ahspurlock likes this.
  11. Aug 25, 2016 at 11:15 AM
    #71
    ahspurlock
    Adam
    yea there is
  12. Aug 25, 2016 at 11:33 AM
    #72
    tacokrys
    krystian
    Very well then. Fj t case it is
    ahspurlock and Aw9d like this.
  13. Aug 25, 2016 at 11:35 AM
    #73
    jowybyo
    Joe
    Baltimore, MD
    Smart choice. Will save you a lot of trouble.
  14. Aug 25, 2016 at 11:43 AM
    #74
    tacokrys
    krystian
    I was leeanibg towards that anyways. My buddy also mentioned a electric front locker. Is that easier said than done?
  15. Aug 25, 2016 at 11:49 AM
    #75
    ahspurlock
    Adam
    dont make one only ARB has one
  16. Aug 25, 2016 at 12:22 PM
    #76
    jowybyo
    Joe
    Baltimore, MD
    What @ahspurlock said. There is only an air locker made by ARB.
  17. Aug 25, 2016 at 12:28 PM
    #77
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
  18. Aug 25, 2016 at 1:35 PM
    #78
    ahspurlock
    Adam
  19. Aug 25, 2016 at 1:36 PM
    #79
    tacokrys
    krystian
    Hmm. I'm gonna have to start budgeting the crap out of the other parts then
  20. Aug 25, 2016 at 1:37 PM
    #80
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    You don't need a locker.....
    Biscuits, Aw9d and ahspurlock like this.
