2x to 4x conversion for my 2nd gen (14)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokrys, Aug 24, 2016.
  1. Aug 25, 2016 at 1:47 PM
    #81
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Out of curiosity has anyone compared the front and rear lockers? I'm sure there probably different but are that that different?
  2. Aug 25, 2016 at 1:50 PM
    #82
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    yea they are
  3. Aug 25, 2016 at 1:51 PM
    #83
    YamaDirtrider
    Josh
    Elizabeth CO
    Have you called junk yards? Between the Tacoma 4Runner and fj you have a better chance of finding local
    ahspurlock likes this.
  4. Aug 25, 2016 at 1:55 PM
    #84
    tacokrys
    tacokrys [OP] Well-Known Member
    krystian
    '14 tacoma full cab trd
    leveling kit, bfgoodrich all terrain ko2, 17in pro comp wheels, bp fabricating skid plate
    How about the front elocker already inside the diff?
  5. Aug 25, 2016 at 2:24 PM
    #85
    YamaDirtrider
    Josh
    Elizabeth CO
    ?? There is no locker, it's an open diff, or are you talking about the add?
  6. Aug 25, 2016 at 2:30 PM
    #86
    tacokrys
    krystian
    I was told its an option that some tacomas came with
  7. Aug 25, 2016 at 2:32 PM
    #87
    YamaDirtrider
    Josh
    Elizabeth CO
    Not that I've ever herd. Only factory one is in the rear.
  8. Aug 25, 2016 at 4:28 PM
    #88
    tacokrys
    krystian
    I'll check it out then
  9. Aug 25, 2016 at 4:42 PM
    #89
    YamaDirtrider
    Josh
    Elizabeth CO
    Are you thinking of doing an fj tcase or stock?
  10. Aug 25, 2016 at 4:59 PM
    #90
    YamaDirtrider
    Josh
    Elizabeth CO
    From the reasurch I've done you can harvest the front diff and cv axels from the 4th gen 4Runner v6or Tacoma.
    Front drive share needs to be from a Tacoma unless you want to modify the 4Runner(it's Leingth is different than taco because of the center limited slip).
    The transmittion can come from a 4gen 4Runner v6 or Tacoma v6 (A750F)
    Tcase from an auto fj
    As for wheel bearing/hubs, go with nj636 or bamatoy1997 they both build hub assemblies on here.
    The tranny cross member I've herd some use the stock 4x one, others say it needs to be cut and welded?!? Idk
    Rear drive shaft needs to be modified, the 4x one had the carrier baring in a different location so it's better to get a shop to modify
  11. Aug 25, 2016 at 9:34 PM
    #91
    tacokrys
    krystian
    Sweet. I'll look into that, the CV axles are what I couldn't find yet, so that helps alot
  12. Aug 25, 2016 at 10:31 PM
    #92
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    rockauto has CV's for a fair price, they have an option for upgraded boots.
  13. Aug 25, 2016 at 11:05 PM
    #93
    tacokrys
    krystian
    I need to start making a list, my head is spinning from all this info.
  14. Aug 25, 2016 at 11:05 PM
    #94
    tacokrys
    krystian
    I live it though
  15. Aug 25, 2016 at 11:05 PM
    #95
    tacokrys
    krystian
  16. Aug 26, 2016 at 1:40 AM
    #96
    YamaDirtrider
    Josh
    Elizabeth CO
  17. Aug 26, 2016 at 2:01 AM
    #97
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Don't forget that the 4runner trail edition also has a manual t-case, but odds are you will probably FJ t-case first and cheaper.
    Biscuits and luka like this.
  18. Aug 26, 2016 at 2:01 AM
    #98
    YamaDirtrider
    Josh
    Elizabeth CO
    Like luka said, rock auto, Amazon, or any auto parts store. Also a place in Denver I've herd builds stronger cv's I think there name was cvj.
  19. Aug 26, 2016 at 9:38 AM
    #99
    Aw9d
    Aw9d That one guy
    I know how you feel! I'm doing the same right now.
  20. Aug 26, 2016 at 9:48 AM
    #100
    luka
    Kailua, HI
    if using the stock system, you'll need the 4wd ecu and plugs/wiring. I'm slowly building a reference list of the plug part numbers and found a place that sells the wire terminals in bulk. the ecu's show up on ebay and not that expensive.
