2x to 4x conversion for my 2nd gen (14)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacokrys, Aug 24, 2016.
  1. Oct 4, 2020 at 5:03 AM
    #121
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    I used the stock 4wd shafts from a Tacoma DCSB front and rear but you'll need to make an extension off you stock location of the center bearing bracket for the drive shaft turn bolt up to on the rear or you can have your drive shaft modified to fit it . If your a 4.0 v6 then you should be 3.73 gear ratio on the rear so you would need a 3.73 differential for the front
  2. Oct 4, 2020 at 8:02 AM
    #122
    Ereyna93
    Ereyna93 Member
    Eddie
    2011 Tacoma silver TRD off-road
    3”lift
    okay I’ll get into it. So the shifter for transfer case goes straight through the floor into coin slot. Did you have to weld or do something custom to shifter ?
  3. Oct 4, 2020 at 8:57 AM
    #123
    ahspurlock
    Adam
    If unmodified the shifter will be in the front pocket just right of the shifter . You will need to cut a hole in the floor board tho
    . If you want it in the coin holder then you'll have to cut the shifter and weld pieces to it to get it there
  4. Oct 4, 2020 at 9:46 AM
    #124
    Ereyna93
    Ereyna93 Member
    Eddie
    3”lift
    Okay awesome that helps a lot awesome!! Thank you.
  5. Oct 4, 2020 at 11:58 AM
    #125
    ahspurlock
    Adam
    Anytime bud
