3” lift and needle bearing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryanlaughland, Jan 4, 2018.
  1. Jan 4, 2018 at 7:00 PM
    Ryanlaughland
    Ryanlaughland [OP] Slater
    Slater
    Austin
    Black 2017 Tacoma DCSB TRD OR
    KB Voodoo bed rack King 2.5 with adjustable reservoirs Toytec AAL Total Chaos UCA Ballistic 16x8” rims Yokohama tires Honeybadger front bumper Smittybilt 20x wireless winch Rigid 30” light bar 2 rigid 10” light bars as floods Prinsu roof rack RCI skid armor CBI battery tray HIDretrofitkit headlights and taillights Pop n lock Meso overhead and lower switch panels Meso interior LED lights AJT designs interior delete kit Rago bed stiffeners Rago left side switch panels Katskillz leather heated and cooled seats Weathertech floor mats and Techliner 3TPAM ARB Safari Snorkel ARB Fridge Slider ARB Elemants 65qt freezer/fridge Main battery is Optima blue top 31 Secondary battery is factory Road shower 4L 10 gal
    So, I was just informed that if you raise a 3rd gen more than 2”, it’ll mess up your needle bearing. Anyone have an issue with this or know if this is a fact?
  2. Jan 4, 2018 at 8:36 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Yes it is a fact.
    ECGS.
    Peace out.
  3. Jan 4, 2018 at 8:41 PM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Mine is 3” no issues. 3k on truck after lift. Save the money and when it happens fix the problem.
  4. Jan 4, 2018 at 9:02 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    Or just do it when your suspension is apart so you don't have to do it later. If your paying someone it may be cheaper to do all at once. I have a 3 inch lift and haven't replaced mine yet only because I do all my own work including alignments
  5. Jan 4, 2018 at 9:07 PM
    doubletap
    doubletap Well-Known Member
    Los Angeles
    2017 Tacoma TRD Offroad MGM
    I only did a 2 inch lift but i will probably replace it when I regear. No problems yet.
    VaToy and Ryanlaughland[OP] like this.
  6. Jan 4, 2018 at 10:18 PM
    coolbhavin
    coolbhavin Well-Known Member
    Tempe, AZ
    2017 TRD Sport; 285's; Method NV's
    Is it necessary to get the removal tool, axle seal, and install tool? I am going to get my truck lifted 3 inches Tuesday but if this is an issue, I may just have the shop install it for me while they are taking apart my suspension.
    Taco_Craig likes this.
  7. Jan 4, 2018 at 10:22 PM
    doubletap
    Los Angeles
    I would like to know this too. I may just buy everything and return the tool if the shop doesn’t end up using it.
    coolbhavin[QUOTED] likes this.
  8. Jan 4, 2018 at 10:40 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    do it now solve the. problem. Toyota didn't, besides who wants. to pay 300 after the fact. I am, only slight vibration at 30-40mph.
  9. Jan 4, 2018 at 10:50 PM
    kuuk
    kuuk Active Member
    SF Bay Area
    2017 trd off road 4x4
    Mine was bad driving away from the shop after a 3 inch lift, just do it all at once.
    coolbhavin likes this.
  10. Jan 4, 2018 at 10:52 PM
    coolbhavin
    Tempe, AZ
    Do you all think I should get the removal and install tool? How about the seal?
  11. Jan 4, 2018 at 10:59 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    yes to all, then resell removal tool and insert tool here
  12. Jan 4, 2018 at 11:13 PM
    doubletap
    Los Angeles
    Were the tools just made so you can DIY or Do you think a professional differential shop can install the ECGS bushing without the ECGS install/removal tool?
  13. Jan 4, 2018 at 11:18 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    I think a pro shop would probably have the proper tools.
  14. Jan 4, 2018 at 11:27 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Buy removal tool and rent install tool from auto zone
    This took me about 30 minutes after I removed the cv. It’s not too hard but it’s a little tricky setting up the removal tool properly
    You forsure need the seal though
    doubletap[QUOTED] likes this.
  15. Jan 4, 2018 at 11:27 PM
    anthony250f
    Anthony
    San Diego, CA
    A pro shop shouldn’t need any additional tools
    doubletap likes this.
  16. Jan 5, 2018 at 4:39 AM
    nailersniper
    nailersniper Well-Known Member
    2017 Limited double cab
    2.5" front and 2" rear with no problem for 1.5 years now with 12,000 miles.
    BroHoGrow, EXTaco and 71tattooguy like this.
  17. Jan 5, 2018 at 5:03 AM
    soup222002
    soup222002 Well-Known Member
    Amelia Virginia
    2017 DCSB TRDORD
    I did this last weekend. Definitely recommend getting the removal tool. I got mine off here. It worked great. You will also need a 35mm socket to remove the cv axle nut. I also bought a seal driver kit from harbor freight for like 30 bucks. I also got the front axle seal from the dealership for 23$. And ecgs recommends replacing your diff fluid with 85-140 for the bushing. The seal part number and oil are located at the bottom of this thread.
    https://www.tacomaworld.com/threads/front-diff-vibes-ecgs-bushing-fix.464941/
  18. Jan 5, 2018 at 5:34 AM
    2k4Taco
    2k4Taco IG: Swannybruh
    Swanny
    Fleming Island, Fl
    16 DC TRD Offroad 4x4
    Icon 2.5s / 2.0's / //Dakar HD Pack//CBI T3 Front/ ATH HC Rear//SPC UCAs/ Camburg LCAs// MR312s w/ 34in Yoko GeoLndrs
    Bro.. Let me rent the removal tool from you!! haha
  19. Jan 5, 2018 at 6:58 AM
    soup222002
    Amelia Virginia
    2017 DCSB TRDORD
    I sold mine Monday to a member on here.
    2k4Taco[QUOTED] likes this.
  20. Jan 5, 2018 at 7:05 AM
    AlabamaBlackSnake
    AlabamaBlackSnake Well-Known Member
    Jim
    4wd TRD OR 2017 dcsb
    Chrome..lot of chrome
    Any amount of lift can cause it to fail. It is a flawed design.
