3” lift and needle bearing?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ryanlaughland, Jan 4, 2018.
  1. Jan 5, 2018 at 7:12 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are all you guys going 3" are getting UCAs as well, right? So you can get decent alignments?
    BlueFalconActual likes this.
  2. Jan 5, 2018 at 7:17 AM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    I prefer to plan ahead of things knowing that it will Eventually fail and it's not a very expensive job to do although I had it installed at ECGS shop.
    soup222002 likes this.
  3. Jan 5, 2018 at 7:24 AM
    kap1425
    kap1425 Well-Known Member
    Kevin
    Tejas
    2017 TRD OR DCLB Magnetic Grey
    Bilstein 6112/5160 Total Chaos UCA's Cali Raised Ditch Lights Katzkin Leather
    You don't want this to happen. The bitch of it is that it is hardly noticeable when it is broken until it breaks something else. if you use 4WD semi-often, just replace it up front. takes 10 extra minutes
    honda50r, SpeySquatch and oscolivar1 like this.
  4. Jan 5, 2018 at 7:26 AM
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Forgot about that too, if you ignore long enough...it's becomes a more expensive job...
    SpeySquatch likes this.
  5. Jan 5, 2018 at 8:52 AM
    coolbhavin
    coolbhavin Well-Known Member
    Tempe, AZ
    2017 TRD Sport; 285's; Method NV's
    It’s just on the front diff on the passenger side right?
  6. Jan 5, 2018 at 9:05 AM
    soup222002
    soup222002 Well-Known Member
    Amelia Virginia
    2017 DCSB TRDORD
    Yes front diff. DRIVERS side
    coolbhavin likes this.
  7. Jan 5, 2018 at 9:44 AM
    yarberrymt
    yarberrymt Well-Known Member
    I just did this in my garage on jack stands to go along with my lift. Might as well do it along with suspension install since you're tearing down the driverside assembly anyway.
    Notes:
    • Regardless of pry bar size, I could NOT get enough leverage to remove the CV from under the car on my back. Had to get a cable and sledge to coax it out. This process seemed WAY easier on 2nd gens from the youtube vids I watched. To save frustration, I would do this, unless you have a lift and can position your body to torque it out. The pry bars were bending on me and the CV wouldn't even budge, even when turning in the shaft in 5% increments to find the "sweet spot". Lots of cursing, but popped right out with cable and BFH method
    • My seal was undamaged, but it doesn't hurt to have a spare to replace it.
    • the ECGS removal tool is a MUST IMO, but you could probably get away with renting a blind hole puller.
    • Make sure you refill the front diff afterwards -- I went with ECGS recommendation 85 -140 Lucas Oil (thicker than snot)
    • I have no vibes after 3 inch lift now, and extra peace of mind.
    YotaKid likes this.
  8. Jan 5, 2018 at 9:45 AM
    yarberrymt
    **I have the ECGS removal tool if you want to buy it off me for a discount. Used for ~3 minutes to get the needle bearing out. PM me
  9. Jan 5, 2018 at 9:47 AM
    coolbhavin
    Tempe, AZ
    PM'd you
  10. Jan 22, 2019 at 8:39 AM
    Mrtoad25
    Mrtoad25 Well-Known Member
    Reno NV.
    2016 TRDSport
    Will I need to replace the seal If my 2016 Tacoma only has 17000 miles on it. I just spent 120 on the bushing and the removal tool. I don't want to spend anymore if i don't need to.
  11. Jan 22, 2019 at 8:43 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Over 40K miles on a full 3" lift. No problems, will replace it when I install new gears.
  12. Jan 22, 2019 at 8:47 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Yes, always replace seals.
  13. Jan 22, 2019 at 10:02 AM
    Mrtoad25
    Reno NV.
    2016 TRDSport
    Its such bullshit that the stealership wont replace my needle bearing under warranty because of my lift.
  14. Mar 26, 2019 at 10:12 AM
    shawn.gossard
    shawn.gossard Well-Known Member
    Shawn
    2016 Tacoma SR5 4x4 Double cab
    Stock
    I cannot even begin to explain how much it pisses me off that only a 2 INCH lift causes this issue. On a truck that is almost garuanteed to be lifted by its owner, you’d think Toyota would have this sorted out.
    With that being said, I will be tearing my front end apart again to do the bushing install soon.. :mad:
  15. Mar 28, 2019 at 8:00 AM
    #35
    Mrtoad25
    Reno NV.
    2016 TRDSport
    Well once you tear it apart and put the new bushing in you will feel better and glad you didnt have toyota put a stock needle bearing in. Its only 2 hours of work so it isnt to bad.....
  16. Mar 28, 2019 at 8:11 AM
    #36
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    How do you figure? No standard warranty will cover damage caused by modifications. The paperwork will state that modifying anything can/will vote your warranty.
  17. Mar 28, 2019 at 8:17 AM
    #37
    Taco_Craig
    Taco_Craig Well-Known Member
    Craig
    2016 MGM Tacoma, DCSB TRD-OR
    RCI Sliders/Plates, Icon [Stage 3] Suspension
    Paperwork isn't the boss of me. I got mine replaced under warranty after a lift. I'm pretty awesome though, so I had that going for me.
    eggs, trktwo, MoonDogSwampFox and 3 others like this.
  18. Mar 28, 2019 at 8:24 AM
    #38
    TurdTaco64
    Brandon
    Fort Collins
    Awesomeness will take you a long way in life.
    trktwo and Taco_Craig[QUOTED] like this.
  19. Mar 28, 2019 at 8:31 AM
    #39
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    It's so true. One of the greatest life hacks
    trktwo likes this.
  20. Mar 28, 2019 at 8:51 AM
    #40
    Mrtoad25
    Reno NV.
    2016 TRDSport
    I don't figure anymore. Replaced it with the new bushing. I am glad they didn't cover it. I feel much better knowing I put a better bushing in it. Thanks Toyota you rock.....
