3” lift and tire rub
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kevovek76, Jul 10, 2021.
  1. Jul 10, 2021 at 4:50 PM
    Kevovek76
    Kevovek76 [OP] Active Member
    Kevin
    2021 Tacoma SR5
    3” front and 2” rear lift, 285/75/17 KO2, 17” method MR301 Wheels
    Hey guys no way was I trying to start an argument over any of this. Was just trying to see what the best fix would be. I haven’t done and alignment yet so maybe this will clear it up. Hopefully I have a buddy running the same set up only difference is he hasn’t done the UCA yet but has had an alignment done
    AmateurTaco1313 likes this.
  2. Jul 10, 2021 at 6:14 PM
    manncyclesupply
    manncyclesupply Well-Known Member
    Mark
    Athens, GA
    2021 dclb TRD Sport 4x4
    Don’t swet people bickering over what methods to use. Start with the alignment and go from there. With a 3” lift I would def recommend an upgraded UCA.
    Also check out the cmc thread referenced earlier. Depending on how you plan to use the truck will determine what you need to do. If your not planning to off road you might get away with alignment only or alignment plus some trimming. If you plan to off road you may need a combination of alignment/UCA, trimming and cmc.
    Good luck and keep us posted with the progress!
    *edit: I see you’ve done the UCA - perfect !
    DavesTaco68 likes this.
  3. Jul 10, 2021 at 7:38 PM
    tommygs3
    tommygs3 Well-Known Member
    tommy
    18 tacoma limited
    Fox 2.0 - KDmax tune - 5.29 revolution
    the right alignment guy should be able to give you an inch forward... if it still rubs, you gonna need to start trimming, then you'll see if you need body mount chop...
    if your gonna do light off roading then just chop it...
    manncyclesupply likes this.
  4. Jul 10, 2021 at 7:50 PM
    Kevovek76
    Kevin
    2021 Tacoma SR5
    Good deal thanks for all the good info guys! I’ll get the alignment and let you guys know what I did to fix it.
  5. Jul 10, 2021 at 9:08 PM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    Since no one could just be straight forward with you, I’ll tell you how it is after a 3” lift and larger tires on these trucks. Aftermarket UCAs. Alignment with 4 degrees of caster. Cab mount chop. Minor inner fender trimming. Presto. You’ll now have a functional, non rubbing, sweet looking truck. Easy as that. Don’t get all confused with these lame answers. It’s not rocket science. And for the guy who took out his whole fender lining, that looks like crap. Don’t go that route.
    philth, Dekoy909, Waynebarkr and 2 others like this.
  6. Jul 10, 2021 at 9:24 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    You’re a saint for answering the same questions over and over.
  7. Jul 11, 2021 at 12:02 AM
    Marvet85
    Marvet85 Well-Known Member
    2021 Tacoma TRD Off-road
    Just starting.
    My solution for the rub was to set the caster all the way forward, @a2lowvw helped me a ton. He is the man and I appreciate him everyday I drive the truck.
  8. Jul 11, 2021 at 12:08 AM
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Keep us posted. Seems as if every truck is a bit different. I have 285/75/16 on stock rig w no rubbing
  9. Jul 11, 2021 at 7:31 AM
    Kevovek76
    Kevin
    2021 Tacoma SR5
    Sounds good will do. Maybe I have to go with 285/75/18 instead. I still have 30 days on these tires
