3” lift now clunk
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PHXTACO-DCLB, Jul 30, 2019.
  1. Jul 30, 2019 at 12:48 PM
    PHXTACO-DCLB
    PHXTACO-DCLB [OP] Member
    Austin
    DCLB silver Tacoma
    I just had a Bilstein 3” lift installed with SPC upper control arms
    And about 75 miles after the install I hear a clunk
    I’m 99 percent sure it’s coming from the driver side front wheel well area
    I hear the clunk every time I go from a stop or hit a bump driving or speed bump
    I can also feel it in the floor when it happens
    Bilstein said it sounds like the grim joints from the SPC upper control arms
    It feels and sounds like something is just slightly shifting but
    I took it in to torque everything to specs 500 miles after install and my mechanic couldn’t figure it out
    Everything Idk re torqued to specs and it’s still happening
    Any ideas on what it might be
    It’s a 2015 tacoma with only 40,000 miles on it
    I just bought it about a month ago
  2. Jul 30, 2019 at 2:03 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    It MAY be your ball joint or bushing in the SPC arms. A few months after installing my new SPC arms I developed a clunk sound during acceleration and hitting some bumps. I ended up having to send my SPC arms back to SPC for their review and they sent me a brand new pair of UCA's. Turns out one of the ball joints went bad.
    The problem was SPC gave me two options. Either I send the arms back and be without UCA's or front the money for a new pair, they send it, I put it on, I send back the former and they'll refund me IF there's a problem they see. It was an inconvenience or gamble one way or another. Plus this didn't include another round of alignment costs.
    One of the bushings also went bad and at the time, SPC didn't have them in stock (neither did Headstrong Offroad). I felt a bit stuck. I ended up just going to Total Chaos uniball UCA's since their parts are readily available and never looked back. I got the SPC arms replaced and instantly sold them locally.
    For what it's worth, most people love their SPC's and never have a problem.
    Hope you get your issue resolved.
  3. Jul 30, 2019 at 2:09 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Sway bar hitting the coil? Did you relocate (or delete) the sway bar?
    Austinguy, Mully and hammertaco11 like this.
  4. Jul 30, 2019 at 2:10 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Sway bar still installed?
    I did the relocation kit on mine after test fitting, found the sway bar connected with the suspension ever so often... usually at full extension or full compression.
    Just a thought.
    I had a bit a clunk after I broke in the new stuff, turned out to be the top nut on the drivers coil over... did you grease the SPC balls after (or before) install?
    hammertaco11 likes this.
  5. Jul 30, 2019 at 4:49 PM
    hammertaco11
    hammertaco11 Well-Known Member
    East Bay, Ca
    2014 Tacoma SR5 Pyrite Mica
    OME lift w/ HD Dakars Pro Comp 17" 7069 BFG KO2 275/70
    x3 on the sway bar. Had a clunk with my lift, didnt notice the sway bar basically touching my coilovers at stand still until I got under and got a good look, which meant it was clunking at all different angles.
  6. Jul 30, 2019 at 4:51 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Swaybar, ditch it. Problem solved and benefits gained. Winning now.
    t0nyvalenzuela likes this.
  7. Jul 30, 2019 at 6:05 PM
    PHXTACO-DCLB
    Austin
    DCLB silver Tacoma
    I haven’t done anything with the sway bar
    But it feels like something is loose and shifting every time I go from a stop
  8. Jul 30, 2019 at 6:06 PM
    PHXTACO-DCLB
    Austin
    DCLB silver Tacoma
  9. Jul 30, 2019 at 6:08 PM
    PHXTACO-DCLB
    Austin
    DCLB silver Tacoma
    @Musubi3
    Did SPC pay to remove and reinstall the control arms? That’s not a part cheap switch out
  10. Jul 30, 2019 at 6:11 PM
    PHXTACO-DCLB
    Austin
    DCLB silver Tacoma
    My sway bar looks like it has plenty of room and there are no marks on the sway bar or coilover indicating any contact
  11. Jul 30, 2019 at 6:12 PM
    PHXTACO-DCLB
    Austin
    DCLB silver Tacoma
  12. Jul 30, 2019 at 6:16 PM
    Musubi3
    Big Island
    No they didn't. I believe I paid the return shipping of the original SPC arms too. Their warranty works through the company you bought it through, FYI.
    Overall, they followed through with their warranty. It just costed me some to deal with it.
    I remember I could replicate the sound by just rocking the truck hard (almost jumping on my sliders). It was only coming out of one side (the passenger side I think).
  13. Jul 30, 2019 at 6:25 PM
    PHXTACO-DCLB
    Austin
    DCLB silver Tacoma
    @Musubi3
    Dang that sucks cause installation isn’t cheap
    Well thx for the help and information
  14. Aug 2, 2019 at 7:01 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Check that your lower control arm bolts are tight. The front and back are different, one tightens with the bolt and one tightens with the nut on the back side. I don't remember which. I had to tighten mine last week because it was making a popping noise when I would go over a speed bump. Three of the four were loose. Not rattling loose, but loose enough that I got at least a half a turn out of them before they seated well. This took care of my problem.
  15. Aug 2, 2019 at 7:10 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Lose the sway bar and the clunk will go away.
    And, no, you won’t die if take the swaybar off.
