3” lift opinions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 434LSU, Feb 3, 2018.
  1. Feb 3, 2018 at 10:39 AM
    434LSU
    434LSU [OP] Well-Known Member
    Baton Rouge
    2017 Tacoma SR5 V6 2WD
    Bought my ‘17 Tacoma a few months back and looking for a quality lift at the best value. I’m new to lifts in general and would really appreciate recommendations and the knowledge shared here.
    I’m considering the 3” RC Suspension (adding front struts) for $500 but don’t like the idea of putting blocks on the rear.
    http://www.roughcountry.com/toyota-suspension-lift-kit-745c.html
    Also considering a coil/Bilstein 5100s lift from Headstrong and adding a rear leaf for $640.
    https://www.headstrongoffroad.com/store/p440/Coil/Bilstein_5100_Kit_-_(HS05BK-1).html
    I see many threads on the Bilstein 5100s and see that they’re adjustable with people running them on the 3rd and 4th notch. However, on the Headstrong site, they recommend keeping the shocks on the 0” or .85” setting (1st or 2nd) and choosing an OEM spring best suited for your trim and lift height.
    Do some people only run Bilstein 5100s all around with no other additional components?
    What spring is best? I was thinking the 887 since it gives the most lift.
    Should I just suck it up and get the complete OME kit from Toytec for around $1200?
    Thanks in advance.
    RobP62 likes this.
  2. Feb 3, 2018 at 10:52 AM
    eon_blue
    Azusa, CA
    You can adjust the 5100s to the 3rd or 4th setting, the issue is that doing so will stiffen your ride considerably. Using the right length springs for the height you want is ideal, it will give you a much better ride.
    Avoid blocks and spacers like the plague unless you want a crappy ride also...those lifts are cheap for a reason. 5100s with OME springs and an AAL in the rear is a very affordable, quality suspension lift setup. Many people here have gone that route.
    RobP62 likes this.
  3. Feb 3, 2018 at 11:00 AM
    434LSU
    Baton Rouge
    Thanks man.
    I guess keeping them on the first or second notch would be ideal. What spring would you recommend? 887?
    How much lift could I expect to get from this lift with the above set up?
    RobP62 likes this.
  4. Feb 3, 2018 at 11:00 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    Since you have a 3rd gen you should probably go with 888. After settling most 2ndgen trucks are lucky to get 2.5" lift from 887's.
    HeadStrong Off-Road and RobP62 like this.
  5. Feb 3, 2018 at 11:01 AM
    434LSU
    Baton Rouge
    Juforrest, it looks like Headstrong only has options of 83, 84, 85, and 87.
  6. Feb 3, 2018 at 11:01 AM
    eon_blue
    Azusa, CA
    Like most things, the more you're willing to pay to more you're going to get out of it...the Toytec setup is a great brand and will probably ride even better than 5100/OME's, but at a higher cost. If you can afford to do it, I would
    RobP62 likes this.
  7. Feb 3, 2018 at 11:07 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Send Marie an email or call on Monday. Also if you put the @ sign in front of the user name it will send the person an alert.
  8. Feb 3, 2018 at 11:09 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    @HeadStrong Off-Road has the best prices with free shipping. Just about everyone else makes go looking for a discount. The standard toytec lift is just rebranded 5100's with their "special" top plate.
  9. Feb 3, 2018 at 11:37 AM
    434LSU
    Baton Rouge
    @eon_blue @Juforrest Do you think my best bet would be the Headstrong package with Bilsteins on second notch (.85”) and 888 springs with single rear leaf?
  10. Feb 3, 2018 at 11:41 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    I would go with 0 setting at first. Let everything break in and settle. You don't really want max everything out without, it's hard on components.
  11. Feb 3, 2018 at 11:46 AM
    434LSU
    Baton Rouge
    @Juforrest I appreciate it. I’ll contact them Monday. This package seems like a solid option overall.
  12. Feb 3, 2018 at 11:48 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    It is, it's a really good entry level setup and will ride nice.
