3.0 v6 has no power!!! Need ideas!!
Discussion in '4Runners' started by NelsonTacoma, Sep 3, 2012.
  1. Sep 3, 2012 at 1:15 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    So my dad and I have been working on my sisters 1993 T4R for about 6 months now (well, when we have time anyway). The auto transmission went bad (pretty sure she over heated it) and it's been in the garage ever since. We bought a used trans/transfer case and had the engine rebuilt. We thought that the engine having no power caused the trans to run in too high of a gear and caused it to overheat, thus killing the transmission. It has always had low acceleration and zero ability to pass on the freeway. Today we finally got everything back together. Well, it still has no acceleration. Even on flat ground. It has new plugs, wires, cap & rotor. The timing is set 10 before TDC. We had a new timing belt, water pump & thermostat put on as well during the engine rebuild.
    We've been thinking that the cat might be plugged and are going to pull that off tomorrow and see if it makes any difference. Anyone have any other ideas on what else could cause the engine to have no power?
  2. Sep 4, 2012 at 6:08 PM
    NelsonTacoma
    Tucson, AZ
  3. Sep 4, 2012 at 6:13 PM
    jobrien
    jobrien shit happens then you die
    Josh
    Ontario California
    2011 single cab base 4x4
    Bed mat, cleats, scangauge, new headlight bulbs, weather techs, more to come
    3.slow brother not much power to begin with if you were to regear youd be happier
  4. Sep 4, 2012 at 6:13 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    3.slow just doesnt have power
  5. Sep 4, 2012 at 8:46 PM
    NelsonTacoma
    Tucson, AZ
    I was hoping that wouldn't be the only answer. We thought with a rebuild it might get better. Sadly my dads turbo 22re 87 pickup (recently rebuilt also) has way more get up and go than the 3.0.
    Oh well....:(
  6. Dec 18, 2012 at 6:03 PM
    Order66
    Order66 Four Wheel Drive With Room For Five!
    Nick
    Georgia
    88 4Runner SR5 V6
    3 inch body lift, 33x12.50x15 Pro Comp A/Ts, Front and Rear Tube Bumpers
    I have a 3.0 in my 88 and has some power. Need to get the oil pump replaced. But I've talked to a few people who have rebuilt the 3.0 (I assume you have the 3VZ-E engine) and said it wasn't worth the money. Something about the blueprinting of the engine not right. They told me (cause I'm planning on rebuilding mine) that it's better to just swap it out with a 3.4. I have found a turbo for like $200 on eBay new. Hope this helps, but from what I've gathered from other people you are going to invest some money into the 3.0 just to get some power.
  7. Dec 19, 2012 at 2:09 PM
    Tommychu
    Tommychu Member
    Power to weight ratio on a 3VZ Runner is about 25lb/hp from the factory, assuming a perfect engine and nothing in the vehicle. So yes, it's just supposed to be that slow. Regear is a good idea but if she does a lot of highway driving I wouldn't bother.
  8. Dec 19, 2012 at 8:46 PM
    Redneck92
    Redneck92 Well-Known Member
    Concord, NC
    02 Tacoma Limited TRD
    Just the norm skids, sliders, & 35's
    3.slow plus auto trans isnt helping the case. 5VZ-FE swap will cure the no power problem. How many miles since the rebuild?
  9. Dec 20, 2012 at 11:53 PM
    Tommychu
    Tommychu Member
  10. Dec 26, 2012 at 6:54 PM
    NelsonTacoma
    Tucson, AZ
    I think we are just going to leave it as is. Right now it's running great & the gas mileage keeps getting better as the new engine breaks in.
    3.slow is what I keep hearing. I'm just used to the 4.0 and that's definitely not a fair comparison. We are up to about 2,000 miles since the rebuild and it's been doing great. No leaks and the trans doesn't hunt for the right gear like it used to. So at this point we are very happy with the truck and plan on keeping it until the wheels fall off.
    True, but this is a DD, not very logical or cost effective. IMO
  11. Dec 26, 2012 at 6:58 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    Do the 3.4 swap. Pretty much the most bullet proof drive train ever.
  12. Dec 26, 2012 at 7:18 PM
    NelsonTacoma
    Tucson, AZ
    It's a little to late for that now........:D
  13. Dec 27, 2012 at 6:58 AM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Sounds like you did the swap eh?
