3,000 miles scalloped tire edges
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Waxcrazy, May 28, 2017.
  1. May 29, 2017 at 4:23 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    The tire pressure on tire is recommend tire pressure to get best wear possible out of that ply an tread pattern. It has nothing to do with what kind of vehicle they go on. Your are suppose to choose your tire accordingly. As long as your are within six psi or so. They should last a while.
  2. May 29, 2017 at 5:02 PM
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    Mine are doing the same, regardless of pressures I have set. My alignment is dead on as well. It's just the nature of the beast and common with the tires that came on my off-road trd. Just keep rotating them at the proper time.
  3. May 29, 2017 at 5:22 PM
    SWB Tacoma
    Arkansas
    I will keep my pressure up an hope for best.
  4. May 29, 2017 at 5:51 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Do you mean they have heel/toe feathering on the edges?
    That's from the tread blocks deforming as they roll/scrub through the contact patch. Sort of normal... Some tires show more than others.
    Sport door sticker is 30psi, and you're at 34psi? So, not under-inflation...
    You can pull in most Toyota dealers and have alignment checked in about 5 minutes.
    Personally, I think you have tires with soft shoulders.
  5. May 29, 2017 at 5:55 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I was told by their senior tech last time that they are just shit tires. :burnrubber:
  6. May 30, 2017 at 9:52 AM
    Waxcrazy
    Waxcrazy [OP] Member
    Wow...just spoke to my dealer and he said that is normal with a tire like that because it is aggressive...I repeated the tire again because I thought he heard me wrong...It's like a car tread for crying out loud...pretty much got blown off...Good ole dealers!!!
  7. May 30, 2017 at 1:57 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    FWIW I've had good luck with Bridgestone Dueler A/T REVO 2..
  8. May 30, 2017 at 3:30 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Just do the chalk test. You'll find your ideal pressure that way.
    The pressure listed on the side of the tire is the Maximum rated pressure for its load rating. Not "ideal for tread contact and wear".
    Camel89 likes this.
