3.0L R150F 3.4L R150F
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hub_G, Nov 22, 2021.
  1. Nov 22, 2021 at 3:14 AM
    Hub_G
    Hub_G [OP] Member
    95 toyota tacoma 4x4
    I've learned that the transmission are the same except for the bell housing, input shaft lengths, and the Transfer case is on opposite sides. I just need to know if I could install a longer input shaft into the 3.0 to make it fit my 3.4. It gotta be way to make this work... someone please inform me about this!!!
  2. Nov 22, 2021 at 3:20 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Try and let us know. You’re very close. Specs like these are usually unknown until you try or get input from someone who rebuilds transmissions for a living.
  3. Nov 22, 2021 at 11:20 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    If you use the 3.0 bell housing it should bolt right up to your 3.4
    I have the same Transmission in my 92 4Runner swap
    Since I am am also using the mated Transfer case .
    I can`t be 100% sure about the transfer case since most people mate the 3.4 to the rest of the 3.0 drive train
    Keep searching the internet your answer is out there some place
  4. Nov 23, 2021 at 5:49 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    check out the toyota 3.4 swap group on facebook. i believe people just use a different thickness flywheel and its a bolt on swap. just mount the taco tcase on back.
    edit: looks like maybe taco tcase wont work
