3+1 Leaf & AAL vs Dakar Height diff?
Discussion in 'Suspension' started by joshuaL401, Sep 2, 2018.
  1. Sep 2, 2018 at 12:14 AM
    joshuaL401
    joshuaL401 [OP] Member
    Joshua
    Tucson, Az
    2007 TRD OR Prerunner AC
    So my current set up is 5100s 884s on all four corners and the stock leaf pack w/ TSB and 1.5 inch AAL. My truck is level (maybe a very very very slight bro lean), which I’m not the biggest fan of.
    I want to go taller though to put on 33s. Planning to switch to 887s and swap in some Dakar's. Would this give me the taller ride height w/ slight rake that I desire?
    I wasn’t too sure about the math and having to account for the TSB on the current set up and no TSB on the future one. Dakar’s are supposed to give 2.75”. Is that w/ or w/out tsb?
    Btw, my truck is an 07 TRD Off Road AC Pre Runner
  2. Sep 2, 2018 at 5:18 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    Without. But 2.75” is what a double cab 4x4 will net. Your AC will net 3”
  3. Sep 2, 2018 at 11:15 AM
    joshuaL401
    Joshua
    Tucson, Az
    I see. Anybody else? So based of the averages/estimates, the combo of 887s and Dakar’s should give me slight rake right?
  4. Sep 2, 2018 at 2:23 PM
    joshuaL401
    Joshua
    Tucson, Az
