3 & 1 lift vs 3" Level
Discussion in '3rd Gen. Tacomas (2016-2023)' started by geno0506, Mar 18, 2016.
  1. Mar 18, 2016 at 8:54 PM
    geno0506
    geno0506 [OP] Well-Known Member
    Michael
    San Antonio, Texas
    Pending....
    Is this considered a normal lift gap and also considered a leveled truck, the kind they want to put on mine, 3 n 1 lift
    whopper and TWTaco like this.
  2. Mar 18, 2016 at 8:56 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Define normal? I'll be honest, as long as you run a 32" tire and don't go over 3" of lift it will look fine and you won't rub things to bad. Other than the flaps, I've seen a lot of problems with rubbing and the flaps on the 3rd gen.
    3" in front and 1" in back is pretty standard on the Tacoma. What will you be doing with your truck OP? All pavement or something else.
  3. Mar 18, 2016 at 9:02 PM
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    Basically all road and some dirt road once in a while but no heavy off road. I guess by standard I mean without looking like a jethro mobile, the shop guy said the set up he gave me was close to a comparison of a 30" tire. with the set up I posted that 4 wheeler quoted me be close to a 32" set up,
    He said I had 2 options, 1 lifting the front only to level it out. 2. do the 3 n 1 and he said the 3 n 1 would be better, I know jack shit about this stuff but does that sone right
    Sorry for seeming such a noob but what is the difference of the 2 and which would you recommend if know I don't want to big of a gap, would he do the front level with a 2" or 3" and the 3 N 1 meaning 3" front and 1" rear!
    I am just confused and thanks a bunch for your help bro!
  4. Mar 18, 2016 at 9:10 PM
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    Here's the pro's of a 2" lift
    1. You only have to pay to lift the front so it's cheaper
    2. The truck will be closer to stock height which is easier to get into
    3. No additional axle wrap (I'm guessing 4wheelparts wants to use lift blocks in the rear :puke:)
    Here's the pro's of the 3+1 lift
    1. The truck will ride higher making it easier to fit a bit more tire
    2. The "look" will likely be a bit better
    Here's the cons of the 2" lift
    1. No lift in rear so no height gain there
    Here's the cons of the 3+1 lift
    1. Likely a bit of axle wrap (effects how the truck takes off when you apply the gas)
    2. Risk of vibes or issues from changing the rear end angles.
    3. You'll be touching the edge of how high the Tacoma can go up front which could wear out the CV boots a bit faster if you hold onto the truck.
    4. Call this 3B but at 3" of lift your alignment will suck with the stock UCA's too.
    Anyways I'm off to bed. Personally, if you are sticking around town, I'd just get some 5100's and set them at 1.75" with the stock coils and call it a day for the suspension. Then throw on 32's and you'll be laughing all the way.
  5. Mar 18, 2016 at 9:16 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Yes, your guys' "3 and 1" is 3 inches up front and 1 inches of lift in the rear.
    Front leveling kit will only lift the front, and it probably 2 inches.
    With 285s or 33" tires you will rub on the inside of the fender. (At least I do with my second gen) not sure what the fender flare looks like on the inside on the 3rd gens.
    A leveling kit will be fine for 275s or a 32" tire!
    geno0506[QUOTED][OP] and Sterdog like this.
  6. Mar 18, 2016 at 9:17 PM
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    Sterdog,
    You've bee a great help and I am thinking of the 5100's and set them at 1.75", and leave back stock right! Are the tires he suggested cole to a 32" with those rims
    If ok, Ide like to talk more when u can bro!
    Thanks
  7. Mar 18, 2016 at 9:19 PM
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    he suggested these
    LT285/70R17, All-Terrain T/A KO2
    is this a good tire ad are these higher and wider then the 285 and 33's, again, I'm learning!
  8. Mar 18, 2016 at 10:26 PM
    Sterling_vH111
    Sterling
    socal
    285/70r17 are about 1.5" thinner than the typical 33x12.5r17 tire. They are also about .3" bigger in diameter. Those are the exact tire size and model I have. Theyve been great tires for me.
    With the 3/1 lift you have picture above, you will clear them fine with no rubbing.
    For a gap picture with the tires he recommended,
    This is my truck with 0" lift on the rear and 1.75" lift in the front. I rub the front fender flares a fair amount, and plan to lift my truck another inch both ends.
  9. Mar 18, 2016 at 10:36 PM
    Scoobarooo
    Scoobarooo Well-Known Member
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    3" OME/Bilstein, Retrofits, Custom Bed rack/Toolbox, Amsoil Everything, tons of others.
    I would just go with 5100's in the front. I have them and I love them. They leveled my truck perfectly. And they're only at half way. I still have more to go if I wanted to lift the rear more
  10. Mar 18, 2016 at 10:40 PM
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    Nice truck,
    So is yours lifted and with what, could I do all that with changing my bilstiens in from and rear to adjustable or whats your recommendation and how will you raise yours like you say!
    I saw this article
    http://www.fourwheeler.com/how-to/1011or-bilstein-5100-leveling-shocks-toyota-tacoma/photo-07.html
    would this be better for my truck and a more reliable and safer way then spacers.
    Thanks
    Screen Shot 2016-03-19 at 12.33.16 AM.jpg 1011or_11_+bilstein_5100_leveling_shocks_toyota_tacoma_2wd_prerunner+toyota_tacoma.jpg
  11. Mar 18, 2016 at 10:42 PM
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    so did you change out yours for the set of 4 - 5100's and are all 4 adjustable, sorry but a little clueless here! :frusty::der:
  12. Mar 18, 2016 at 11:44 PM
    Sterling_vH111
    Sterling
    socal
    Correct. Adjustable bilstein 5100 shocks with either the stock coils set on the highest ring (2.5") or lift springs with the bilstein 5100's on the lowest ring should suit your needs for the 285 bfg's recommended.
    I'd recommend these springs if you decide to go that route:
  13. Mar 19, 2016 at 12:00 AM
    Sterling_vH111
    Sterling
    socal
    I have Fox 2.0 Coilovers, they are similar to the bilsteins, but have threads for more fine tune adjustment, as opposed to 3 preset snap in place rings.
    Keep in mind rear shocks won't give you lift, but will increase damping performance.
    I plan to get a new spindle to lift my front as I am only 2wd Prerunner, 4wd trucks cannot use them. (I assume you are a 4x4 right)
    I am going to get a 1.5" add-a-leaf for the rear to keep the truck mostly level and not too much lean!
  14. Mar 19, 2016 at 7:20 AM
    FarmBoyTaco
    FarmBoyTaco Work Hard, Stay Humble
    Josh
    California
    '12 TRD Off-Road DCSB MGM
    No, the rear is not adjustable. Like the previous post above me said, rear shocks don't lift. It doesn't matter what brand you buy, a rear shock doesn't lift.
  15. Mar 19, 2016 at 7:27 AM
    #35
    Scoobarooo
    Casey
    Brooksville, FL
    '02 DCSB TRD OR
    You're fine man. Honestly.
    5100's are only adjustable for the front.
    Grab yourself a set of those and start there. It's by far the easiest way to go.
  16. Mar 19, 2016 at 9:30 AM
    #36
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    thanks
    :thumbsup:
  17. Mar 19, 2016 at 9:33 AM
    #37
    geno0506
    Michael
    San Antonio, Texas
    Pending....
    Thanks all for your help,
    Appreciate it!
  18. Mar 19, 2016 at 9:34 AM
    #38
    Toddcoma16
    Toddcoma16 Member
    Todd
    2016 Black Tacoma 4x4 SR5 XP
    Those of you who have lifted your trucks, what kind of price are we looking at?
    I am probably just looking to lift the front to level out and run some bigger tires.
    Also what kind of gas mileage difference have you seen?
  19. Mar 19, 2016 at 10:16 AM
    #39
    Mjordan
    Mjordan Well-Known Member
    Michael
    Denver, Colorado
    2015 Super White DCSB 4WD TRD Offroad
    TRD Beadlock Wheels, Bilstein 5100s all around, BFG K02 265/75R16, 20% tint, WeatherTech Floormats, LED Interior Lights, Tailgate lock, Salex Organizers, Shorty 5" Antenna, LED license plate lights
    I recently went through this dilemma, so I'll tell you what I went with after countless hours of research and decision making. Note that I'm in a 2015 TRD Off-Road.
    - Front and rear Bilstein 5100's, with the front at the 1.75" setting.
    - Stock coils.
    - 265/75R16 BFG KO2's
    Looked great, but it was slightly nose high. So I installed some 1" rear blocks. They ended up being about 1.25" actual measurement, so my nose is about .25-.5" lower now haha... But I don't mind it because if I ever have anything in the bed it evens out and my nose isn't pointing to the sky. And I think only I can tell the difference honestly.
    I'm happy with how it looks and rides. Anything more up front and I would have to spend $400 on new UCA's to get proper alignment. My gas mileage has decreased about 1-2 MPGs because of the heavier/bigger tires.
    I very rarely get off the pavement, except for a mild gravel/dirt road to a local gun range sometimes. It was relatively inexpensive compared to some other options, and leaves me plenty of money for other mods. Highly recommended way to go IMO.
  20. Mar 19, 2016 at 11:12 AM
    #40
    FarmBoyTaco
    Josh
    California
    The biggest factor in mileage will be the tires.
