3/2 ready lift questions
Discussion in 'Suspension' started by Skylarc, Oct 30, 2022.
  1. Oct 30, 2022 at 8:55 PM
    Skylarc
    Skylarc [OP] Member
    Skylar
    2014 Tacoma TRD Sport
    I’ve been looking at a 3/2 block and spacer lift, but im hearing mixed opinions. My tacoma’s a pavement princess and i just want a little more height without having to pay a couple grand. Is something like this legit and is it sustainable? Do i need to replace uca’s, tie rods, bump stops, etc?
  2. Oct 30, 2022 at 9:16 PM
    Bishop84
    Bishop84 Well-Known Member
    There's thousands of tacomas running around with leveling kits just blocks.
    Just be aware that its not ideal for offroading or towing and understand that its more for looks and you're good.
    I'd suggest the front 2 1/4" and 1" rear to reduce issues, but 3 and 2 is very common.
    Biggest issues are ball joint wear and cv boot wear due to strong angles.
    Skylarc[OP] likes this.
  3. Oct 30, 2022 at 9:35 PM
    Skylarc
    Skylarc [OP] Member
    Skylar
    @Bishop84 Thanks for the reply, is there a specific brand you trust more than others? I also plan to run new wheels is there a recommendation on what specs i could run on 2 1/4” and 1” without a cmc?
