3.4 4wd Starter
Discussion in '1st Gen. Tacomas (1995-2004)' started by ico135, Jun 7, 2017.
  1. Jun 7, 2017 at 6:26 AM
    ico135
    ico135 [OP] Member
    Tupelo, MS
    I am trying to remove my starter from 2002 V6 4wd Tacoma and have hit a road block. How in the world do you get it out. I have watched a few videos and they all seem to have the 2wd version where you can unbolt and move the brake line. This is not possible with the 4wd version.
  2. Jun 7, 2017 at 6:37 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    This is a 4x4 4Runner.
  3. Jun 7, 2017 at 6:54 AM
    ico135
    ico135 [OP] Member
    Tupelo, MS
    The Tacoma brake line is different than his. The second bracket is welded to the frame so it can not be removed like he did.
  4. Jun 7, 2017 at 6:55 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Bummer :(
  5. Jun 7, 2017 at 7:00 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    So it's all unbolted you just need to get it out?
  6. Jun 7, 2017 at 7:06 AM
    ico135
    ico135 [OP] Member
    Tupelo, MS
    Yeah i have it all unhooked and free, just still in the truck engine bay. Apparently being V6, 4wd, and an automatic makes it impossible to remove. Well impossible may not be accurate, but as i look into it one person even posted a video of how to rebuild it while in the truck.
  7. Jun 7, 2017 at 9:21 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I cursed Toyota engineers for a couple of hours when I changed mine. The brake line has to be disconnected from where it mounts on the frame and very carefully pushed aside a bit, then the starter has to be turned a certain way to slide out of the gap, I can't remember just which way you will have to experiment.
    Colangeli likes this.
  8. Jun 7, 2017 at 12:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Is it an issue with auto vs manual? I bought my truck with a new starter so I never had to do it.
  9. Jun 7, 2017 at 4:01 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Can you just remove the brake line then? It would require you to bleed the brakes but it would solve your problem of getting it out and then you can follow the video of mine @Dalandser posted to rebuild your solenoid. To keep the brake line from dripping and losing a bunch of brake fluid, a 7/32" vacuum cap fits nicely over the flared tubing end to stop it from leaking.
    Dalandser likes this.
  10. Jun 7, 2017 at 8:57 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    When I pulled mine I went under the truck not through the wheel well. Literally had it out in 1 minutes once it was unbolted. All I did was remove the exhaust support bracket ( 3 bolts) and it slid right out
    Kwe1982, The Driver and Dalandser like this.
  11. Jun 8, 2017 at 12:46 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    What about unbolting the two motor mount bolts on the right side and jacking the engine up a little?
    1997tacomav6 and Dalandser like this.
  12. Jun 8, 2017 at 1:24 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Maybe the Automatics are different my 5 speed I don`t recall any major problems when doing the clutch .
    Truck was on Jack stands and it dropped out the bottom .
    Then I have been doing this sort of thing a few times
  13. Jun 8, 2017 at 9:58 AM
    ico135
    ico135 [OP] Member
    Tupelo, MS
    Wyoming09, yes the automatics are different than the manual. Apparently any combination except, v6-4wd-automatic, has a reasonably easy path of removal. Removing the exhaust support bracket would probably work but i can't verify that personally.
    I was able to resolve the issue though. So i ended up just pulling the plunger and contacts from the starter with it still in the engine bay, replaced them, and reinstalled. Fires up perfectly again.
    cruiserguy and Dalandser like this.
  14. Jun 8, 2017 at 7:42 PM
    04George
    04George Well-Known Member
    Colorado
    ‘04 xcab TRD Off-road & ‘23 Taco TRD Off-road 4 door stnd. bed
    I ran into the same problem when I replaced my starter, I ended up just twisting it all sorts of ways and found that bring it out from down below past the exhaust/manifold was the best way. Spent like a good 30 mins before I finally got it out.
  15. Jun 8, 2017 at 7:45 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    legend has it, that you -can- tetris it out
    same story on 4runner, can be done, but I abandoned and moved brake line after 20 minutes failing
    cruiserguy likes this.
  16. Jun 9, 2017 at 1:25 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That's some McGyver stuff there. Good work. Glad you got it fixed :)
  17. Jun 9, 2017 at 1:35 AM
    yayayayayaya
    yayayayayaya Active Member
    Patrick
    Alaska
    1999 V6 Tacoma
    Keeping it tame
    Ive heard that you have to remove the transmission dip stick. Then remove it through the wheel well. I have to do this soon too. Starter contacts are worn out. One guy in a video I watched did it really easy, and then another guy didn't remove it at all and just fixed the problem under his truck after he removed the starter. So.... if you figure it out let us know.
    jammer and Dalandser like this.
  18. Jun 9, 2017 at 1:40 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    He said he fixed it without removing it from the engine bay.
    yayayayayaya[QUOTED] likes this.
  19. Jun 9, 2017 at 8:59 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Another reason to love 2.7 :yes:
  20. Jun 11, 2017 at 9:09 AM
    Matermax
    Matermax Well-Known Member
    Nathan
    NE Arizona
    1999 Tacoma TRD
    White Line LCA bushings.
    If I remember correctly I had to remove the exhaust bracket on mine (manual transmission) but it's been a while
