3.4 4wd Starter
Discussion in '1st Gen. Tacomas (1995-2004)' started by ico135, Jun 7, 2017.
  1. Aug 9, 2020 at 8:13 AM
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    I know it’s an old thread but I just did this today and thought I’d share.
    With the v6 auto 4x4 I do not know how you’d get the starter out the side. I already had ditched my sway bar so I just cut the bracket off and it was able to drop out the bottom pretty easily. To install I had to unbolt the trans dip stick from the block (1 12mm bolt, easiest from the underside). With that loose it popped right into place. Hope this helps someone.
  2. Aug 9, 2020 at 8:45 AM
    1997tacomav6
    Denver
    I like this idea, my starter is original still and its something I will have to do at some point.
    But I have headers and there's no way its coming out from the bottom or top.
    You and support the engine from the oil pan without any issues to remove the motor bracket?
  3. Aug 9, 2020 at 9:05 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    you can support it from a long 4x4 piece of wood and a floor jack on the pan. But after you get it raised, slip some small blocks between the motor mount and frame for safety.
  4. Aug 9, 2020 at 9:09 AM
    Jguardino
    Jguardino Well-Known Member
    jacob
    209
    01 Dbl cab, 22 TRD OR PREM
    you have it to Jimmy it out at a weird angle towards the crossmember. My buddy helped me and I could not got it however he found the g spot apparently and got it lol
  5. Aug 9, 2020 at 10:53 PM
    Colangeli
    Colangeli Well-Known Member
    Alex
    She's a god damn trooper. 95, 3.4, lifted, welded, 'merica muffler,
    Cup holders, oh she's got a sweet feather in her bumper
    Pull the tranny dip stick, un mount alot of the hard lines to the cooler, and toe the line of shoving them out of the way and fucking yourself. That's the only way I got it
  6. Feb 9, 2022 at 11:42 AM
    coopnugz
    coopnugz Well-Known Member
    Cooper
    2022 Black Trail
    Gonna have to do this to mine, glad this thread exists as I have the v6 4x4 auto… luckily I have already ditched antisway bar so hopefully that will make life a bit easier like mentioned above.
  7. Feb 10, 2022 at 11:22 AM
    tpole
    tpole Active Member
    It's not the end of the world. I did mine a few months ago in the office parking lot in the rain. Took less than two hours.
    Once you unbolt the starter, you can rotate and wiggle it to just clear the above-mentioned trouble spots. It's a sort of Twister-like game, but it has the room to drop free.
    coopnugz and Dalandser like this.
  8. Nov 6, 2022 at 6:08 PM
    ValenC
    ValenC New Member
    Does anyone have a good video of this being done on 3.4L V6, 4x4 Auto? I am completely buggered on how to get the starter out, for all of the reasons mentioned by the people above with this same truck. This combo is nigh on impossible.
  9. Nov 6, 2022 at 6:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Undo bolts, and pull it through the wheel well (passenger side).
    Let's call the part of the starter that bolts in place part A, the part facing towards the rear part B.
    When you undo the starter, pull it and angle part B downward with part A facing up. Pull part A up and out towards the opening.
  10. Nov 6, 2022 at 8:38 PM
    Slysock
    Slysock Member
    99 Mobile Home
    Stock
    Depending on the dexterity of your hands, ability to stay calm/curse at yourself, you can separate the solenoid from the starter. There are two bolts that hold the body and one that hold the electrical cable. Make sure you reassemble it the way you take it apart. It splits it in half and makes it easy to remove and replace.
    It’s tedious but not necessary move anything else.
  11. Nov 7, 2022 at 5:32 AM
    coopnugz
    Cooper
    2022 Black Trail
    https://www.tacomaworld.com/threads/just-found-the-first-thing-i-really-hate-about-my-tacoma.774564/
    Several different approaches described in the above thread for how to Jimmy the little bastard out. Some have had luck from above or from the passenger wheel well. I had luck pulling it out from below past the steering rack. Sounds like it will depend on your configuration a bit, the auto trans makes it harder… I have a 2.5” lift and no sway bar which I’m convinced made it a lot easier.
  12. Nov 8, 2022 at 5:28 AM
    1997tacomav6
    Denver
    At 700,000 miles original starter went south,
    Come to find out with the headers on and 5 speed with twisting the starter to the right position it WILL drop right out the
    bottom. It ended up being a 30 minute job max, what a relief
    Area51Runner likes this.
  13. Nov 8, 2022 at 5:59 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Auto 4x4 offers much less room than a manual 4x4.
    Huge difference.
    1997tacomav6[QUOTED] likes this.
  14. Nov 8, 2022 at 10:07 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Exactly how I removed it. Bring it out by dropping it down and out over the steering rack. Much easier and enough room not to have to fuss with it.
