3.4 Cal vs. Non Cal Air fuel sensor
Discussion in 'Technical Chat' started by Blue Truck, Jun 27, 2019.
  1. Jun 27, 2019 at 4:58 AM
    Blue Truck
    Blue Truck [OP] Well-Known Member
    A few weeks ago I had to replace upstream A/F sensor, got home with the new part and the connectors were different, turned out the part number is for CA emissions which the vehicle doesn't have. The wires are the same, so needing the vehicle I trimmed the tabs so the connector would fit. Now I am getting P1135 heater circuit. I guess I am wondering if the difference between the two would be causing the P1135. The engine seems to run fine.
  2. Jun 27, 2019 at 8:33 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    What year truck? IIRC ‘01-‘04 were almost all CA spec, with a few exceptions.
    I would guess that the ECU is expecting a different voltage for the heater circuit, so while the sensor might not be bad it probably is what is causing the DTC. Recommend getting the correct sensor and plug for your truck.
  3. Jun 27, 2019 at 9:02 AM
    Blue Truck
    It is a 99 4runner limited
  4. Jun 27, 2019 at 3:52 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Might be a poor connection on the heater circuit
