3.4 Cooling Bypass Tube
Discussion in '1st Gen. Tacomas (1995-2004)' started by Clucky, Sep 4, 2015.
  1. Sep 4, 2015 at 8:03 AM
    Clucky
    Clucky [OP] Well-Known Member
    W
    WC to EC back to WC
    00 SR5 Stock 5 Speed
    & 12 TRD Stock 6 Speed
    My FSM and Haynes seem to leave out any install details on this piece. There appears to have been an O-ring (there's some leftover pieces may be) on the flange connection to the block but my replacement didn't come with one. Does this part get an O-ring and/or FIPG? Thanks.
  2. Sep 4, 2015 at 10:00 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    FIPG, no O-ring. The detailed instructions are in the FSM at the end of "Engine Mechanical 5VZ" (reassembly). There is a groove but it is for the FIPG material.
  3. Sep 4, 2015 at 7:12 PM
    Clucky
    W
    WC to EC back to WC
    Yes, I see that section now, kind of in a strange spot. Thanks for the info.
  4. Sep 5, 2015 at 4:32 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Hey what's your issue as to why you're replacing this part? It seems I've got a tiny coolant leak coming out from behind that plate in the back of motor where the bypass tube enters is why I ask. I've done a little bit of research into this and find it can be a few things. Won't know till I tear the whole top end down to figure it all out. Really anxious about it and wondering if you had the same issue and what it was if that was the case with yours..
  5. Sep 5, 2015 at 8:30 AM
    Clucky
    W
    WC to EC back to WC
    I happen to have the heads off, due to some compression issues. While in there, I noticed a bit of liquid in the little valleys between the freeze plugs below the where the tube runs. Although I never noticed a loss of coolant before, I figured it was a good time to get a new one along with the knock sensor cable as well.
