3/4 Cross country trip photo dump
Discussion in 'Travel' started by fatfurious2, Jul 26, 2021.
  1. Aug 9, 2021 at 9:51 AM
    #41
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Good thinking to bring that with you.
    Keep us posted on what you find. I'd bet the alignment is off somewhere if it ate a new belt in 200 miles
  2. Aug 9, 2021 at 9:56 AM
    #42
    fatfurious2
    fatfurious2 [OP] IG: great_white_taco
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Going to pull skid. Its 2x 17mm, and 2x 13mm. But damn its heavy
  3. Aug 9, 2021 at 10:07 AM
    #43
    fatfurious2
    David
    Ashburn, VA
    Found the rest of the belt around the tensioner pulley. But everything still spins freely. Any indication of something off?
  4. Aug 9, 2021 at 10:21 AM
    #44
    fatfurious2
    David
    Ashburn, VA
    New belt on, skid about to go on. Then will monitor next gas stop
    airmax233 likes this.
  5. Aug 9, 2021 at 10:26 AM
    #45
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Id wager a bad belt. Youre pulleys arent magically going to change distance. Or your tensioner is failing.
    Lmk if youre still coming through kc
  6. Aug 9, 2021 at 10:35 AM
    #46
    fatfurious2
    David
    Ashburn, VA
    I like this way of thinking. Maybe Dayco > Gates?
    I will be on the way back. So, probably after the 16th.
  7. Aug 9, 2021 at 10:39 AM
    #47
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Nah. Gates is good. Just manufacture issue im sure. If you have problems again then id lean tensioner. Also i wouldnt have been afraid to run 1 less rib. Not the end of the world if you were in a pinch.
  8. Aug 9, 2021 at 10:47 AM
    #48
    fatfurious2
    David
    Ashburn, VA
    I may have run it if i was mid trail, but im in a city, so a quick stop for a $30 belt was probably a good idea. Next time I know though
    Bastek and BassAckwards like this.
  9. Aug 9, 2021 at 2:16 PM
    #49
    fatfurious2
    David
    Ashburn, VA
    ~125 miles since belt change, and no issues. Belt looks good so far
  10. Aug 9, 2021 at 2:41 PM
    #50
    fatfurious2
    David
    Ashburn, VA
    Ohio was pretty flat. Not much happening. 292 miles until Chicago
  11. Aug 9, 2021 at 3:36 PM
    #51
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    CHICAAAGO!
  12. Aug 9, 2021 at 5:04 PM
    #52
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    OMG! I'm having dejavu! I replaced my belt 2 months before taking a trip to North Carolina a couple years ago. It shredded on the trip home. Had to replace it in an Oreilly Auto Parts parking lot with the skids on. It had wrapped around the crank pulley and screwed the seal. I was stipping every 2 hours to add oil until I got it home.
    My guess is it was off a groove on one of the pulleys when you replaced it. Make double sure the new one is on ALL grooves. Good luck!
  13. Aug 9, 2021 at 5:49 PM
    #53
    fatfurious2
    David
    Ashburn, VA
    I will check oil levels at my next stop. Thanks for that tip!
    Im 100 miles outside of Chicago
  14. Aug 9, 2021 at 10:21 PM
    #54
    fatfurious2
    David
    Ashburn, VA
    Red roof inn, Rockford IL.. hope i don't die tonight :anonymous:
    lets also hope the truck has wheels in the morning
    airmax233, gwiz and Bastek like this.
  15. Aug 10, 2021 at 5:03 AM
    #55
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
  16. Aug 10, 2021 at 5:12 AM
    #56
    fatfurious2
    David
    Ashburn, VA
    It was awesome to meet you! :hattip: Thanks for hanging out for a little bit
    uploadadventure likes this.
  17. Aug 10, 2021 at 5:16 AM
    #57
    GARSHA91
    Chicago
    Same here. I hope the food did not disappoint.
  18. Aug 10, 2021 at 5:24 AM
    #58
    fatfurious2
    David
    Ashburn, VA
    The gyro was good!
  19. Aug 10, 2021 at 5:29 AM
    #59
    Pa_Slasher
    Pa_Slasher Well-Known Member
    2025 Blue Crush Metallic TRD Sport I Force Max
    Stock
    Sub'd on here and the Gram!
    airmax233 and fatfurious2[OP] like this.
  20. Aug 10, 2021 at 6:08 AM
    #60
    fatfurious2
    David
    Ashburn, VA
    Today, trying to drive from Rockford IL to Oacoma SD. Will not be staying in red roof in.
    And from there, Bozeman is an additional 9.5 hours away.
    Bastek and w.adventures like this.
