3.4 dies after 1-3 seconds after start
Discussion in '1st Gen. Tacomas (1995-2004)' started by stinkyspice, Apr 24, 2018.
  1. Apr 24, 2018 at 5:18 PM
    stinkyspice
    stinkyspice [OP] Well-Known Member
    okay so my friends 3.4 97 4Runner just dies on him driving about 30 on the highway. now it dies after start up. it will run about 1-3 seconds it will run. sounds like it gonna go then turns to a real rough idle and can hear in the airbox like its grasping for air then it dies.
    i can hear the fuel pump whine and start up.
    changed the fuel filter and there was still pressure in the system
    changed the MAF sensor.
    Cleaned out the Idle Control Valve
    vacuum lines seem to all be in place.
    im kind of stumped.
    could it be the CAMSHAFT position Sensor?
    any ideas help.
  2. Apr 24, 2018 at 5:23 PM
    stinkyspice
    i tried that. still does the same thing. i believe these engines need the MAF plugged in and working to run.
    ill try it again.
  3. Apr 24, 2018 at 5:52 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Go to auto zone and rent a fuel pressure gauge. See what kind of pressure you got.
    Remove top timing belt cover and check cam timing also. No codes or check engine light?
    Running Board Man likes this.
  4. Apr 25, 2018 at 12:10 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    The ECU needs a signal back from the ignition to keep firing the injectors and keep the fuel pump on. Ignition needs crank and cam sensors signals to fire the spark plugs.
    Are there any codes? Try looking at live data from the code scanner to gain any insight too.
  5. Apr 25, 2018 at 12:18 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They've changed ecus lots more than that, 95,96,97,98-99,00,01-02,03,04 ecus don't last long in the Toyota world haha
  6. Apr 25, 2018 at 1:03 AM
    stinkyspice
    It’s not throwing any codes at all. I’ll try Check the fuel pressure. I really don’t think that’s it though because it’s fairly new
  7. Apr 25, 2018 at 1:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    No light pretty much says a fuel delivery problem.
    unless your light is burned out ?
    It does come on with ignition switch on ?
  8. Apr 25, 2018 at 1:37 AM
    stinkyspice
    It’s come on before on his truck. So it’s not burned out. Maybe we will just swap the fuel pump out
  9. Apr 25, 2018 at 10:10 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It your project do what works best for you
    Know going in just a new pump might not solve the problem.
    Best of luck
  10. Apr 25, 2018 at 10:17 AM
    eon_blue
    Azusa, CA
    Maybe it is throwing a CEL but it's not running long enough to trigger it? 1-3 seconds before dying is pretty quick. If you can plug in a code scanner or have a shop do it and see if it's throwing a code or a pending code (which wouldn't trigger the CEL) maybe it will help point you in the right direction.
  11. Apr 25, 2018 at 1:37 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    Are you throttling at start up? Try giving it some throttle as soon as start up occurs to see if it will run under throttle. If so, if it continues to die at idle, I would suspect Idle Air Control valve. I know initial post said IAC was cleaned, but I had an IAC go bad before and was similar - easy start up but dies right away. I'm so used to not throttling newer cars that it took a while to figure out.
    Let us know what you figure out, good luck!
  12. Apr 25, 2018 at 7:01 PM
    stinkyspice
    Thanks for all the input guys!!
    It will die even when throttling at start up too. When I feel the line it doesn’t feel like a steady flow of fuel. I’m thinking it’s the pump after all not giving enough pressure. There is no valve on the fuel rail to test pressure.
    Is there a valve anywhere? I can’t find one.
  13. Apr 25, 2018 at 7:12 PM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    When you start it have someone beat on the gas tank with a bar or rubber mallet. Make sure your hitting the tank and not skid. If pump has low pressure usually it will revive the pump enough for the motor to run. Then you know the pump has failed.
    If there are plans to ever supercharge its a good time to upgrade the fuel pump to a 190lph. It can handle it stock. I recommend an oem pump from a Mitsubishi lancer evo 8/9. Can find them used cheap sometimes and they are high quality denso. But you also want the harness and plug to make splicing easy. Or you can go with a walbro but they tend to fail and whine pretty loud.
    arifleman likes this.
  14. Apr 25, 2018 at 7:55 PM
    stinkyspice
    Just beat it and it was running a little longer than normal. Gonna pick up a fuel pump tomorrow!! Thanks!
  15. Jun 15, 2018 at 3:46 PM
    stinkyspice
    so it ended up being the wiring from the plug to the fuel pump. the gasoline ate up the old set up so i made up a new wiring harness and that did the trick and changed the pump sine we where in there. thanks guys for all the help and suggestions.
