3.4 engine hesitation
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andyd103, Jul 19, 2016.
  1. Jul 19, 2016 at 2:30 PM
    Andyd103
    Andyd103 [OP] Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    I have a problem where cold or warm my truck under medium-hard acceleration will ramp up fine dump into the next gear and then have a problem creating power for a second and then picks back up. A slight lag in acceleration. I'm considering replacing the MAF sensor which was rebuilt and not denso. Anyone have any ideas? NO CEL, new plugs and wires (not coil packs), fresh oil, pcv, etc etc, just can't hunt it down.
  2. Jul 19, 2016 at 4:43 PM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    If you have a OBD2 scanner you can read the mass air flow reading and see if anything looks out of wack
