3.4 engine ticking noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eatbeers1stgen, Feb 23, 2020.
  1. Feb 23, 2020 at 10:42 AM
    Eatbeers1stgen
    Eatbeers1stgen [OP] Well-Known Member
    2001 Toyota Tacoma 4x4 manual
    Ome front coils and shocks (881) All pro rear leafs Custom welded front Baja bumper Elocker from trd Tacoma with low range wiring harness.
    Never has the check engine light came on, or flashed. Yes comes on with other lights when key is in ignition
  2. Feb 23, 2020 at 10:43 AM
    Eatbeers1stgen
    I did redline the engine a couple times cleaning out carbon deposits...
  3. Feb 23, 2020 at 10:44 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    just keep driving it
    Eatbeers1stgen[OP] likes this.
  4. Feb 23, 2020 at 10:49 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Check the plugs. They can get loose, particularly on the 3.4.
    Speedytech7[QUOTED] likes this.
  5. Feb 23, 2020 at 10:50 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    :eek:
    wilcam47 likes this.
  6. Feb 23, 2020 at 10:54 AM
    Eatbeers1stgen
    Now I’m scared
  7. Feb 23, 2020 at 11:06 AM
    Black DOG Lila
    Virginia
    RED is the international color of
    DANGER
    WARNING
    DON'T DO IT
  8. Feb 23, 2020 at 11:07 AM
    Eatbeers1stgen
    When I feel the injector coils on the passenger side of motor , the middle one seems to feel like it’s vibrating more then the rest
  9. Feb 23, 2020 at 11:14 AM
    Eatbeers1stgen
    Exhaust seems to make a cough like noise.. like it’s missing
  10. Feb 23, 2020 at 11:57 AM
    Eatbeers1stgen
    newer oil change and put about a ounce of seafoam into engine before this was ever a issue.... this was about a week ago going after a different problem I was having. Should I change the oil ?
  11. Feb 23, 2020 at 2:19 PM
    Eatbeers1stgen
    SOLVED: engine tuck came from a spark plug that has play in it. Felt the injectors and middle one felt like it had a lot of ticking to it. Boot is torn on injector coil, but spark plug had weird up and down play. Posting video in a sec. highly recommend checking plugs for play.
    rackomint and underaroof like this.
  12. Feb 23, 2020 at 2:41 PM
    Eatbeers1stgen
  13. Feb 23, 2020 at 2:48 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  14. Feb 23, 2020 at 2:49 PM
    pablotaco
    pablotaco Well-Known Member
    San Diego
    02 PreRunner
    That’s great. My 02 has been doing that too, and only when it’s warm as well, not quite as bad but worth checking the plugs. Thanks for sharing.
  15. Feb 23, 2020 at 3:21 PM
    #35
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Congratulations! If you need a new injector pigtail, I bought mine at O'Reilly. If you are careful, you can pull the wires out of the old and transfer them to the new plug socket.
    mattyosh likes this.
  16. Feb 23, 2020 at 3:40 PM
    #36
    Eatbeers1stgen
    ///Meant coils not injectors ////
  17. Feb 23, 2020 at 3:42 PM
    #37
    Eatbeers1stgen
    I noticed that my engine would kinda spudder without sending a code which led me to believe it was spark related
  18. Feb 23, 2020 at 5:12 PM
    #38
    pablotaco
    San Diego
    02 PreRunner
    I think the noise on mine is more of a chirping and appears like it might be coming from an after market water pump. Probably ok, just isn’t that smooth hum I’d prefer. Plugs look fine but do need replacing.
  19. Feb 23, 2020 at 8:24 PM
    #39
    AKJC77
    AKJC77 Member
    96’ Tacoma DLX 3.4 V6 4X4 Auto
    Might wanna check to make sure you don’t have a bad ignition wire or Spark plug if your getting misses. They can tick if they are bad, could also be injector going bad.
  20. Feb 23, 2020 at 9:10 PM
    #40
    Eatbeers1stgen
    Although ticking is gone with new plug, I still have a miss that just happened today. Finally as I was going up a hill in 4th gear Truck started shaking and shuttering until cel flashed. Def a misfire, the plug cylinder coil is torn and had rubber all inside the hole the plug goes into... think it’s running hotter ?
