3.4 hill pulling rpm.
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoTim34, Oct 28, 2014.
  1. Oct 28, 2014 at 9:31 AM
    TacoTim34
    TacoTim34 [OP] New Member
    Tim
    Mesquite nv
    00 tacoma 3.4 sr5 2.5" lift
    2.5" lift, light bar
    I bought a 2000 tacoma 3.4 manual a few months ago. This is my first experience with a tacoma and with a manual trans. Pulling hills on the freeway I usually leave it in fifth gear which doing 70 to 75 has the Rpm between 2600 and 2800, if I can maintain this speed in fifth but can't really accelerate should I just downshift? I'm worried about lugging the engine excessively. Is this high of rpm enough to keep adequate oil pressure for the load on the engine?
  2. Oct 28, 2014 at 9:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If it's holding speed, you're fine. Downshifting won't hurt, but isn't necessary. You aren't lugging the engine at that RPM.
  3. Oct 28, 2014 at 12:40 PM
    Indy
    Indy Master of all I survey.
    Anything above idle is enough oil pressure.
  4. Oct 28, 2014 at 3:16 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    well you have a lift too correct? and bigger tires? if so, you're just feeling all of that take it's load. downshifting is perfectly fine so long as you're not skipping gears or dropping to a redline.
  5. Oct 28, 2014 at 4:27 PM
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    It has multiple gears for a reason so don't be afraid to use them. :)
    If applying more throttle doesn't get you more speed, then you need to downshift.
  6. Oct 29, 2014 at 12:02 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    i meant dropping into a redline, not accelerating into a redline.
  7. Oct 29, 2014 at 1:42 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    quite true
