3.4 IAC valve
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by 97tacotruck, May 7, 2022.
  1. May 7, 2022 at 10:28 AM
    97tacotruck
    97tacotruck [OP] 1st Gen, Best Gen
    Josh
    Socal
    ‘97 v6 4x4 m/t SC’d
    289k+ Miles 1st gen TRD supercharger w/ 2.2 pulley Snow Performance Stage 2 water/methanol Method NV 305 Bronze 16x8" Falken Wildpeak AT3 OME Nitrochargers w/883 coils Atlas Spring Leafs +3/4” lift Corbeau Seats Total Chaos UCAs PowerStop Drilled & Slotted Rotors, Pads, Calipers Stainless Brake Lines Projector 5x7 headlights w/Morimoto HIDs All-Pro Baja Front Bumper All-Pro Skid Plate Warn Evo VR 8s Winch Baja Designs Squadron Sport Fog Lights Prinsu XtraCab Rack RotoPax Bed Mounted Gas Packs Bushwacker Bed Caps Raptor Liner Bed DeeZee Bed Mat LED Bed Lighting RGB Rock Lights Polk Audio Speakers Alpine Headunit and Amp 8in Subwoofer 00-04 Center Console Needle Bearing Delete ARB compressor (engine bay)
    OEM for a 3.4.
    Works great. Bought because I thought my high idle was caused by my IAC, turns out my throttle cable was too tight. :/
    $100. you pay shipping
  2. May 10, 2022 at 10:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    How long was it on your truck?
  3. May 11, 2022 at 3:36 PM
    97tacotruck
    Josh
    Socal
    ‘97 v6 4x4 m/t SC’d
    I never installed it. Bought it from another member that was working fine
  4. May 11, 2022 at 4:50 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It does look clean on the inside. GLWS
