3-4" Lift Help - OME vs ICON
Discussion in '3rd Gen. Tacomas (2016-2023)' started by YOTABrendan, Nov 17, 2016.
  1. Nov 17, 2016 at 7:24 PM
    YOTABrendan
    YOTABrendan [OP] Member
    Brendan
    2016 TRD Sport 4x4
    Hey everyone, I'm looking at getting an overall 4" lift to my Taco. I'm fairly new to mods but have definitely done a ton of research, I've narrowed it down to these two options:
    - OME 2" ARB Lift Kit. - I've read somewhere that it's really a 2.5" front lift, is this true?
    - ICON Stage 2 0-2.75" Lift.
    Add on:
    HS 1/2" Top Plate Spacer
    Bilstein's 1" Body Lift
    This should give me 3 1/2 - 4" of lift if I go with the OME's, or 4 - 4 1/2" with the ICON's.
    First of all, is it possible to add the top plate spacer with either of these lifts?
    And, if I max out the ICON's to 2.5" or even 2.75", is my suspension range going to suffer? I've read somewhere that if you max out Bilstein's 5100 to 2" then your compression range is just... crap.
    I looked at the Rough Country 4" Lift but I feel like the components they use aren't going to do my truck justice.
    I'd like to hear everyone's thoughts on this & open suggestions.
    - B
  2. Nov 18, 2016 at 12:28 AM
    Midknight
    Midknight Well-Known Member
    Western Canada
    2018 TRD Off-Road
    my 2c, I'm not a fan of stacking lifts like this, but if I were to chose between your setups I guess I'd do the Icon suspension
    Law950 likes this.
  3. Nov 18, 2016 at 10:36 AM
    YOTABrendan
    Brendan
    2016 TRD Sport 4x4
    Any reason you're against it?
    What kind of setup would you suggest otherwise?
  4. Nov 18, 2016 at 10:41 AM
    lose_money
    lose_money Well-Known Member
    Dean
    2016 MGM TRD OR 4x4 MT
    King 2.5, Icon AAL, SCS Ray10 16x8
    scarp the spacers and body lift and go with either of your first two options standalone
    Joe23 likes this.
  5. Nov 18, 2016 at 10:43 AM
    YOTABrendan
    Brendan
    2016 TRD Sport 4x4
    Any good coil-overs that'll add 4" on their own?
  6. Nov 18, 2016 at 10:44 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No.
    greeneggsnspam likes this.
  7. Nov 18, 2016 at 10:44 AM
    Midknight
    Western Canada
    2018 TRD Off-Road
    A suspension lift is done for performance and a spacer/block lift is done more for looks imo. I feel like having both kind of undermines the upgraded suspension. That being said, please take what I say with a grain of salt. This is just my opinion on if it were my truck, but there are people who have done exactly what you are proposing.
    I guess I would also ask why you are set on a 4" lift.
    Also this may be helpful
    https://www.tacomaworld.com/threads/6-lift-on-2016-tacoma.396217/
    Don't forget too that taller tires will also get you a bit higher off the ground
  8. Nov 18, 2016 at 10:45 AM
    lose_money
    Dean
    The angle on your CV axles would be too steep. How come your set on having 4inch of lift?
    doorsidedown likes this.
  9. Nov 18, 2016 at 10:46 AM
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    Even if there were, your cv axles would hate you. Even 3" pushes it.
  10. Nov 18, 2016 at 10:46 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    What size tires are you wanting to run?
  11. Nov 18, 2016 at 10:48 AM
    YOTABrendan
    Brendan
    2016 TRD Sport 4x4
    I'm not necessarily set on 4". It's that I would like something more noticeable than 3" while not hitting the 6" range and having to modify the crossmember and regear (assuming I go with 35s).
    Looking at running 33s, maybe 34s
    I could always throw on a diff drop kit
  12. Nov 18, 2016 at 10:49 AM
    lose_money
    Dean
    You can fit those size tires without going with the spacers. Even 35's if your willing to do a bit of trimming
  13. Nov 18, 2016 at 10:52 AM
    doorsidedown
    doorsidedown Well-Known Member
    This. If you're set on a 4" lift, get one that's meant to give you 4" of lift. BDS makes one. If you stack lifts, you're asking for trouble and won't compensate for the stuff a designed 4" lift compensates for (like CV angles)
  14. Nov 18, 2016 at 10:52 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Skip the spacers.
    Go with whatever lift you want.
    33s will fit fine with whatever minimal lift and trimming you do. Especially if you go with skinnier tires rather than big wide dopey mud terrains just for looks like most peeps haha.
    Joe23 likes this.
  15. Nov 18, 2016 at 10:53 AM
    T4RFTMFW
    What does that have to do with CV angles?
  16. Nov 18, 2016 at 10:56 AM
    YOTABrendan
    Brendan
    2016 TRD Sport 4x4
    Diff drop kit*
  17. Nov 18, 2016 at 10:57 AM
    T4RFTMFW
    You should do a lot more reading on lifts, IMO.
    Goobersbro and Joe23 like this.
  18. Nov 18, 2016 at 10:59 AM
    YOTABrendan
    Brendan
    2016 TRD Sport 4x4
    Hahaha this ^
  19. Nov 18, 2016 at 11:00 AM
    FinnJ
    FinnJ Well-Known Member
    Finland
    2007 FJ Cruiser 6M/T
    TRD SC, UCON, CNG conversion, RC 6" (lifted 4"/3" air suspension) w/FOX 2.5, 315/70R17 Duratracs, RECARO seats, etc.
  20. Nov 18, 2016 at 11:25 AM
    PJnc284
    Garner, NC
    Didn't really improve things on the 2nd gen so I wouldn't expect it to make a significant difference on a 3rd either.
