3.4 Lower Radiator Hose for taller radiator (AT Radiator?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeWH, Jul 12, 2020.
  1. Jul 12, 2020 at 5:00 PM
    MikeWH
    MikeWH [OP] Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Been going through my truck - 1999 3.4L 4x4 Manual, doing timing belt, etc. I had a nice new OEM lower radiator hose ready to go for it. I also got a Denso radiator off of Rock Auto or Amazon. Seems only the AT version of the radiator is available, which is what i got. This means it's about 2" taller and has the ATF cooler hose fittings on the bottom. This also means the lower hose port is lower, and my OEM hose won't work (not enough offset).
    My hose is a 16572-07030.
    I think I need 16572-07040. I'm going off what ToyotaPartsDeal.com is telling me, says the ....40 part fits code 4FC (instead of VZN160 or 170R which I think is the manual code).
    Can anybody verify before I purchase? Or maybe just head to NAPA.
    Thanks!
  2. Jul 12, 2020 at 5:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd just get the hose meant for an automatic Tacoma; should be your best bet.
    Sorry that I don't have parts numbers for you.
  3. Jul 12, 2020 at 5:15 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    Thanks, that is definitely the plan, just hoping to verify fitment before making Toyota richer haha
  4. Jul 12, 2020 at 5:59 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    That is the part number I see on partsouq as well, with a possible substitution??? Screenshot_20200712-185729.jpg
  5. Jul 12, 2020 at 6:06 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    More then once when the hose was to short I cut it in the straight section found a piece of pipe or tube to fit the ID as a temporary fix . That never got changed till the coolant came out in a year or two
    When getting the correct part at that time was not a option
    cruiserguy likes this.
  6. Jul 12, 2020 at 6:18 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    Thanks, I’ll try that one! Not sure what the substitution is, I don’t see it online.
  7. Jul 12, 2020 at 6:20 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    I have done that before on another car and it actually worked well haha! Luckily I have 2 trucks so I can use the other one till I get the right part. It’s been down 3 weeks so a couple more days won’t kill it. Still waiting for my fuel injectors on it too!
    Wyoming09[QUOTED] and cruiserguy like this.
  8. Jul 12, 2020 at 6:23 PM
    cruiserguy
    Elijah
    SEKS
    Perfect. :cool:
    Yes, ignore that trash part #, I shouldn't have even mentioned it:Dnot sure why they list it. But no matter. You got the right part #
  9. Jul 12, 2020 at 6:27 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    Appreciate it! Usually Toyota parts deal lists it as “replaced by...” if there is a newer part number, and what you get in the mail is the new number, even if ordering the old number. Figured it may be something like that but didn’t make sense. What is PartSouq anyways?
    cruiserguy[QUOTED] likes this.
  10. Jul 12, 2020 at 6:28 PM
    cruiserguy
    Elijah
    SEKS
    Great diagrams. The best for diagrams! partsouq.com
  11. Jul 12, 2020 at 6:29 PM
    cruiserguy
    Elijah
    SEKS
    It'll take a few minutes to get quick with navigating it but man, it has had every diagram I've needed
    MikeWH[QUOTED][OP] likes this.
  12. Jul 19, 2020 at 7:58 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    To close the loop on this- the 16572-07040 is the correct hose for a 3.4 w/Auto Transmission Radiator. Had to pay List for this at th elocal Toyota Dealer which is about double what you can get it for online. Ouch. But it fit!
    Burro and cruiserguy like this.
