3.4 Ltr Engine
Discussion in '1st Gen. Tacomas (1995-2004)' started by Prerunner99, Nov 12, 2017.
  1. Nov 12, 2017 at 2:06 PM
    Prerunner99
    Prerunner99 [OP] New Member
    Pete
    Tacoma Pre Runner
    I have a Toyota PreRunner 1999 that was running hot so I changed the Radiator, waterpump, radiator cap, fan pully. It kept running hot so I took it to a Mechanic that told me the Head Gasket was Blown. after having it for 1 1/2 months he told me it was ready. I picked it up and drove it for about 2 months and it started running hot again. I took it back and he said he would do it again. I picked it up for the second time and it still ran hot. Being frustrated and deciding he did not know how to fix it I took it to another Mechanic that had a Great reputation for fixing cars and Trucks. He told me without breaking the motor down his conclusion was that the Block was cracked. Is there a way to know for sure that this is the problem without breaking the motor down. There was no water in oil or any common symtoms. Any ideas?
    PK
  2. Nov 12, 2017 at 2:10 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    You could take the radiator cap off while it's cold then crank it up and see if you have any bubbles. Or get a cooling system pressure tester. I think someone makes a dye kit where you pour some stuff in the radiator and it tells you if you have a gas leaking into the coolant system.
  3. Nov 12, 2017 at 5:03 PM
    TaCoJoE650
    TaCoJoE650 Cars are the sculptures of our everyday lives.
    Joey
    Bay Area
    99 tacoma 2WD 2.4L
  4. Nov 13, 2017 at 12:53 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Ask the second mechanic what evidence he has for this - if he's actually a good mechanic he'll tell you with an actual diagnosis - otherwise he's just making assumptions. It shouldn't be a secret.
    What engine do you have, the 2.7?
