3.4 mpg
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma1965, Aug 25, 2019.
  1. Aug 25, 2019 at 6:38 PM
    Tacoma1965
    Tacoma1965 [OP] Active Member
    Anthony
    98 tacoma 4x4
    3 inch lift. 2857017
    Hey what's the average fuel mileage for a 3.4l with 2857017 at tires?
  2. Aug 25, 2019 at 6:50 PM
    BeLance89
    BeLance89 Well-Known Member
    Brandon
    Huntsville, AL
    2002 White TRD double cab
    Gear ratio? Auto or manual?... just kidding. None of that really matters. You should be around 15-17 MPG. I have 285/75/16 wildpeak MTs with 4.88s and avg 16.5
  3. Aug 25, 2019 at 6:50 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    Not sure of ratio. It is automatic.
  4. Aug 25, 2019 at 6:53 PM
    BeLance89
    Brandon
    Huntsville, AL
    If you haven’t swapped gears, you more than likely have 4.10s. You’ll probably be closer in the high 15mpg with the 33 inch tires. But it’s also dependent on how much hwy/cty driving you do.
  5. Aug 25, 2019 at 6:54 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    Drive 12 miles a day on freeway . I can watch the fuel hand move.
    jammer likes this.
  6. Aug 25, 2019 at 6:56 PM
    BeLance89
    Brandon
    Huntsville, AL
    What are you getting per tank?
  7. Aug 25, 2019 at 6:57 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    About 130 miles.
  8. Aug 25, 2019 at 6:57 PM
    BeLance89
    Brandon
    Huntsville, AL
    You should be getting double that.
  9. Aug 25, 2019 at 7:00 PM
    BeLance89
    Brandon
    Huntsville, AL
    Any CEL or rough idle, hard starts, or anything like that?
  10. Aug 25, 2019 at 7:01 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    I know. It's got 154000 miles. I just got it 3 weeks ago. Its had a ton of work on it. Toyota installed new frame. New axle shafts. Radiator, exhaust, air filter, I just thought mpg would be better. Dont know how old ign parts are, wires look brand new
  11. Aug 25, 2019 at 7:02 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    No cel, starts great.
  12. Aug 25, 2019 at 7:03 PM
    BeLance89
    Brandon
    Huntsville, AL
    When you get to “E” does your tank take close to 16 gallons?
  13. Aug 25, 2019 at 7:04 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
  14. Aug 25, 2019 at 7:06 PM
    BeLance89
    Brandon
    Huntsville, AL
    Have you plugged in an OBD2 reader just to be sure of no stored codes? Previous owner could’ve pulled the CEL bulb. There’s some squirmy bastards out there.
  15. Aug 25, 2019 at 7:06 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    I just figure it's the bigger tires. Sure has lots of power.
  16. Aug 25, 2019 at 7:08 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    I have not. It does a bulb check when u turn ign on. Also cant get key out of ignition half the time . Have to keep taking in and out of park.
  17. Aug 25, 2019 at 7:14 PM
    BeLance89
    Brandon
    Huntsville, AL
    Well, color me stumped. That may require some professional looking over.
  18. Aug 25, 2019 at 7:15 PM
    Tacoma1965
    Anthony
    98 tacoma 4x4
    I appreciate the help. I may pull plugs and look at them. Also fuel filter.
  19. Aug 25, 2019 at 8:28 PM
    c0climber
    c0climber Well-Known Member
    Northern Colorado
    2001 Tacoma
    I get around 19.5 on the highway with my wild peaks on. Generally around 320 miles ro a tank.
  20. Aug 25, 2019 at 8:33 PM
    BeLance89
    Brandon
    Huntsville, AL
    Size tires and gear ratio?
