3/4 of my rear brake clips failed overnight
Discussion in '2nd Gen. Tacomas (2005-2015)' started by a89aries, Oct 21, 2012.
  1. Oct 21, 2012 at 1:28 PM
    a89aries
    a89aries [OP] Well-Known Member
    Alex
    London Ontario
    09 Tacoma TRD offroad
    Drove home last night, no issues. This morning I go to leave and the truck is stuck, can't even budge it in 4l, forward or back. I quickly realize the back axle is locked solid on both sides.
    I immediately assume the worst, that the diff failed and some part fell in and jammed it, preventing both sides from turning.
    Not the case, pulled the drums to find that somehow 3 of the 4 spring retainers had failed, everything was just chilling in the bottom of the drum. You can see in the photo how it somehow pulled the pin right through the clip. Everything else looks fine, a little dusty if anything but wear wise, no problems.
    Going to try and pick up a spring kit tomorrow and put it all back together.
    Quick search turned up nothing, any ideas people?
  2. Oct 21, 2012 at 1:32 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Looks heavily corroded. I see you have a '09. Did you service the rear brakes last year? Suppose to do it every two years, especially in heavily-salted winter environments like yours.
  3. Oct 21, 2012 at 2:31 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    corroded? thats nothing...ive seen a lot worse than that still holding on...been doing drum brakes for 30 years. i think id check to make sure the backing plate is secure. its also possible that your wheel cylinder is seized on one side
  4. Oct 21, 2012 at 4:29 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Did you back the breaks off first? looks like you forced the drum over the break shoes and pulled the pins through the retainers.
  5. Oct 21, 2012 at 7:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Brake not break!
    This seems a more likely event than " The brakes worked fine when you parked it and the clips forced themselves off while it was parked overnight". I think it is fairly impossible for the clips to fall off while parked.
  6. Oct 21, 2012 at 7:48 PM
    a89aries
    Alex
    London Ontario
    I backed the brakes off before pulling the drums, obviously there was still some resistance. I'm not a brake expert, but I've pulled off much more corroded systems before without pulling the pins.
    The wheel cylinders are in a+ shape, cylinder pushes back and forth smoothly with no issues.
    Going to toss a new spring kit on tomorrow.
