3.4 overheating HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by LittleDoubleCabBoy, Mar 25, 2019.
  1. May 21, 2019 at 7:08 AM
    LittleDoubleCabBoy
    LittleDoubleCabBoy [OP] Member
    Colton
    2002 F&R Locked Tacoma DC
    Fab and Toyota repair shop in my town that I've used a lot has a new mechanic so I'm not sure who checked it out for me but he said he thinks its cylinder head gasket
  2. May 21, 2019 at 7:08 AM
    LittleDoubleCabBoy
    Colton
    ANY OTHER OPINIONS???
  3. May 21, 2019 at 7:09 AM
    Rons01TRD
    Rons01TRD Well-Known Member
    Ron
    Virginia Beach, VA
    2007 4Runner 4WD
    My 1999 has an indication issue, after about 10 minutes the temp gauge pegs. I have replaced everything in the system to be sure and I installed a scan gauge and it is running normal temps. Some say it is a ground under the dash. I have not since tried to troubleshoot it since I leave the scan gauge plugged in.
  4. May 21, 2019 at 8:53 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Plenty
    cruxofthebisquit likes this.
  5. May 21, 2019 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You said you checked the oil recently?
    White smoke paired with milky oil would definitely cause me to look towards replacing the head gasket. However, if you're not experiencing the two things I mentioned, then that mechanic is quick to try and take you for a fool. Replacing the head gasket can be labor intensive.
    Go back and read everyone's suggestions to monitor your temperatures and monitor any symptoms. You can begin diagnosing your vehicle by hand to see if you have cold spots on your radiator, cold hoses, etc. These things will not only help you better understand how your vehicle works, but also save you money by not trusting a stranger to diagnose your vehicle and cause you to throw money at your vehicle unnecessarily.
  6. May 21, 2019 at 10:53 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    *looks for clutch fan on his manual trans*
    hey wait a minute....
    greengaint97 likes this.
  7. May 21, 2019 at 11:00 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    take the radiator off and really, really clean it out. Back wash, front wash, look inside, watch how fast water flows one end to the other.
    A clogged one will usually even feel heavy. A new one is freakishly light.
    greengaint97 and OneWheelPeel like this.
  8. May 21, 2019 at 12:00 PM
    greengaint97
    greengaint97 Well-Known Member
    Al
    Colorado's Western Slope
    SOLD: 01' TRD xtra cab 3.4L five speeder
    Replaced my [radiator] last week. Was having intermittent issues with running hot. Likely the thermostat was the culprit (replaced); did 5 flushes of distilled, paired with a new radiator, Toyota Red and silicone hoses, and I feel good about my typical/expected operating temps now.
    Certainly smart to give the radiator a good going over; or, just replace it. They are pretty cheap (less than $100).
