3.4 starts but won't run???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bobothehobo, Nov 12, 2017.
  1. Nov 12, 2017 at 4:20 PM
    Bobothehobo
    Bobothehobo [OP] Well-Known Member
    1999 SR5 3.4l
    3.4 starts for about 5 seconds then quits. Giving it gas doesn't help. Replaced fuel filter & checked fuel pump
  2. Nov 12, 2017 at 4:22 PM
    Glamisman
    Glamisman Well-Known Member
    all of the sudden problem or ?
  3. Nov 12, 2017 at 4:23 PM
    Bobothehobo
    1999 SR5 3.4l
    Yeah, drove fine yesterday
  4. Nov 12, 2017 at 4:24 PM
    4x4runner2002
    4x4runner2002 Well-Known Member
    Zach
    2002 4x4 limited
    suspension and armor
    Check the flux capacitor
    Gonna need more info
    Bobothehobo[OP] and MatthewMay1 like this.
  5. Nov 12, 2017 at 4:25 PM
    4x4runner2002
    Zach
    2002 4x4 limited
    How many time did you turn it on and then it died?
  6. Nov 12, 2017 at 4:26 PM
    12Mk6gti
    12Mk6gti Well-Known Member
    Scott
    Sunshine state
    2019 Nautical Blue TRD OffRoad 4Runner
    How does the engine sound when it runs for these 5 seconds, rough/smooth?
  7. Nov 12, 2017 at 4:26 PM
    Glamisman
    you verified the fuel pump opperation how?
  8. Nov 12, 2017 at 4:26 PM
    Bobothehobo
    1999 SR5 3.4l
    Started fine this morning, then when driving started running bad, like not on all cylinders(shaking) then quit & now will run for 5 second and quit. No codes or engine light
  9. Nov 12, 2017 at 4:27 PM
    Bobothehobo
    1999 SR5 3.4l
    Remove fuel line from filter and started, got soaked
  10. Nov 12, 2017 at 4:28 PM
    12Mk6gti
    Scott
    Sunshine state
    Disconnect the maf sensor and see if it runs....
  11. Nov 12, 2017 at 4:28 PM
    Glamisman
    so it looked like 40 psi?
  12. Nov 12, 2017 at 4:30 PM
    Glamisman
    the PCM has the ability to store "pending" codes... if you have a scanner check and see.
  13. Nov 12, 2017 at 4:33 PM
    Bobothehobo
    1999 SR5 3.4l
    Disconnect maf and it runs
  14. Nov 12, 2017 at 4:36 PM
    12Mk6gti
    Scott
    Sunshine state
    It stays running when the maf is disconnected?
  15. Nov 12, 2017 at 4:37 PM
    12Mk6gti
    Scott
    Sunshine state
    Do you have a stock air intake on your truck? I'd try cleaning the maf for now with some maf cleaner and then eventually replace it so it doesn't become an issue later down the road.
  16. Nov 12, 2017 at 4:41 PM
    Bobothehobo
    1999 SR5 3.4l
    Yes run's good with maf disconnected
  17. Nov 12, 2017 at 4:43 PM
    Bobothehobo
    1999 SR5 3.4l
    Yes stock intake
  18. Nov 12, 2017 at 4:44 PM
    12Mk6gti
    Scott
    Sunshine state
    Ok
  19. Nov 12, 2017 at 4:45 PM
    Bobothehobo
    1999 SR5 3.4l
    Thanks to you all for your help
  20. Nov 12, 2017 at 4:45 PM
    12Mk6gti
    Scott
    Sunshine state
    No problem!
