3.4 Supercharger help needed (02 tacoma)
Discussion in '1st Gen. Tacomas (1995-2004)' started by BlackPearl, Aug 6, 2019.
  1. Aug 19, 2019 at 7:36 PM
    #61
    BlackPearl
    BlackPearl [OP] Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    Well I installed a new injector and at first it wasn’t firing, drove it around and it started working. Cleared the codes and now I’m getting a pending code p0300. Engine is running on all 6 cylinder but I’m getting some random misfire somewhere. Any ideas?
  2. Aug 20, 2019 at 7:20 AM
    #62
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Clear your ECU and try again. Could be some air in your fuel lines. Could also be that your stock ECU doesn't like the new injectors :notsure:
  3. Aug 20, 2019 at 8:17 AM
    #63
    BlackPearl
    Alex
    Toyota Tacoma TRD
    If the stock ecu doesn't like the fuel injector would a piggy back fix this issue?
    and I have cleared the light a few times. This last time its not showing up on my dash but the reader picks it up as pending code.
  4. Aug 20, 2019 at 10:26 AM
    #64
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I don't know. How big are the injectors? Could be running was too rich. In that case, yes, a controller would fix it (piggy back or standalone).
    I would reset and retry though, in case it was air in the fuel line.
  5. Aug 20, 2019 at 11:47 AM
    #65
    BlackPearl
    Alex
    Toyota Tacoma TRD
    After last reset the code hasn't come back yet. Another unusual thing happened today. I went to start the truck and it cranked but wouldn't start. Then after cranking and giving a little bit of gas it fired up. I let it run and warm up and tried again to see if it will repeat and this time it cranked for 15-20 seconds before it started up. After driving it around a few miles I tired again and this time it fired right up. Not giving me any codes.
    Maybe the injectors are to big. Could be flooding the cylinders? they are 305cc.
  6. Aug 20, 2019 at 12:00 PM
    #66
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Try unhooking the battery for 30 min to do a good reset on the computer. I don't think the injectors would be causing an issue, if the working properly.
  7. Aug 20, 2019 at 12:09 PM
    #67
    BlackPearl
    Alex
    Toyota Tacoma TRD
    Thanks, Ill give it a try
  8. Aug 20, 2019 at 12:33 PM
    #68
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    This sounds like air in the fuel lines but could be flooding cylinders. When you give it "gas" you're actually just giving it air (opening the TB). The extra air could have helped detonate fuel in a flooded engine. 305cc should be ok but you will def need a piggy back to keep from running too rich.
    Do you have an AFR sensor? Should consider getting one with the S/C. Will help with troubleshooting, tuning, and monitoring.
  9. Aug 20, 2019 at 2:50 PM
    #69
    BlackPearl
    Alex
    Toyota Tacoma TRD
    I don't have an AFR sensor but looking into getting one. was thinking to get a boost gauge with integrated AFR that way I would only need a single pod but not sure how good they are.
  10. Aug 20, 2019 at 5:51 PM
    #70
    OldWrencher
    OldWrencher Member
    Dave
    2000 Tacoma
    TRD supercharger and 7th injector kit
    I also experienced the HG-LR (higher gear - lower RPM) pinging with the stock pulley (5 or 6 pounds of boost), and I live at 5400 feet.
    In URD's defense, I don't believe they wrote that software, but I otherwise agree. It is crap.
    BlackPearl[OP] and eon_blue like this.
  11. Sep 5, 2019 at 3:58 PM
    #71
    BlackPearl
    Alex
    Toyota Tacoma TRD
    Ok I have yet another update.
    Today I was driving from my lunch brake and my truck started acting strange, code came on as I sat at a red light and the really rough idle began. I turned the truck off and cleared the code but nothing changed. Then the light came on and the truck barely went 10mph... I tried giving it throttle but it only grabs at about 85-90% open throttle. anything lower the RPMs stay low almost like a limp mode.
    The code that came on is P0172 (oxygen sensors detect that the air fuel mixture is too rich). It cant be a dirty sensor since I just cleaned it a few weeks back.
    Any idea what this could be?
  12. Sep 5, 2019 at 4:34 PM
    #72
    mechanicjon
    Jon
    Scottsdale Arizona
    What year truck? What does the scanner show for TPS readings?
  13. Sep 5, 2019 at 4:55 PM
    #73
    BlackPearl
    Alex
    Toyota Tacoma TRD
    Its an 02 and how do I get TPS reading?
  14. Sep 5, 2019 at 4:56 PM
    #74
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Throwing this out as a shot in the dark but I read you changed the fuel pump... did you also change the fuel pressure regulator? I've never boosted anything but if your throwing more flow at it don't you need to compensate for the pressure change as well?
    BlackPearl[OP] likes this.
  15. Sep 5, 2019 at 5:09 PM
    #75
    BlackPearl
    Alex
    Toyota Tacoma TRD
    I did upgrade the fuel pump and injectors but if the FPR was not letting enough fuel into the system it would be running lean not rich. I could be wrong tho...
  16. Sep 5, 2019 at 6:40 PM
    #76
    mechanicjon
    Jon
    Scottsdale Arizona
    Check the FPR vacuum line, make sure it doesn't have any fuel in it.
    You need a scanner to get TPS readings.
  17. Sep 5, 2019 at 8:48 PM
    #77
    BlackPearl
    Alex
    Toyota Tacoma TRD
    I have an ultra gauge but not sure how to find that reading.
    I did drive the truck home after work and it ran completely fine.
  18. Sep 6, 2019 at 7:47 AM
    #78
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    You can't run bigger injectors on stock ECU.
  19. Sep 6, 2019 at 8:08 AM
    #79
    Abeyancer
    Jimmie
    PNW
    I thought all you had to do was just "reset" the ECU when you install the kit.. pull the ECU fuse for a solid 15min then off to the races
    I also don't have a SC installed so I'm purely speculating here based off info I've creeped from other posts
  20. Sep 6, 2019 at 9:15 AM
    #80
    mechanicjon
    Jon
    Scottsdale Arizona
    One your scan gauge when in the gauge mode, just push one of the buttons until the "TPS" comes up.
