3.4 supercharger motor questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Grizzly Guy, Jan 8, 2014.
  1. Jan 8, 2014 at 10:48 AM
    Grizzly Guy
    Grizzly Guy [OP] Member
    Jack
    Oregon city
    1999 supercharged sr5 Tacoma
    Supercharged 3.4,Nine inch lift, locked front and rear, headers, etc
    I got a factory supercharged 3.4 wondering if there is any difference between the regular efi 3.4 and the SC 3.4? I'm gonna buy a new long block and throw the SC on it. What I'm asking is are the block/heads/internals the same? Thanks in advance, jack
  2. Jan 8, 2014 at 11:16 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    nope. Totally the same.
    Id look into adding the URD 7th injector kit though to help with pinging issue to get extra fuel...maybe even add a URD pulley wheel for more boost :devil:
    but block wise. Totally the same. The TRD SC just replaces the stock intake manifold.
  3. Jan 8, 2014 at 11:25 AM
    Grizzly Guy
    Jack
    Oregon city
    Okay thanks! I have a bigger pully and 20% bigger injectors but I've been looking into the seventh injector kit, and a FIC do u have any knowledge about a FIC?
  4. Jan 8, 2014 at 11:28 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Presumably you meant smaller pulley..as that's what gives you more boost.
    You can essentially create the same power/ping elimination with 6 larger injectors, larger fuel pump and a piggyback as doing a 7th injector, fuel pump with a piggyback. URD offers both kits.
  5. Jan 8, 2014 at 11:42 AM
    Grizzly Guy
    Jack
    Oregon city
    Yes... Ill check it out not sure what a piggyback is. What oil can I run in the cone i got some gm stuff cuz toyota wanted an arm and a leg for there stuff. I think it's the third gen SC
  6. Jan 8, 2014 at 11:49 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Piggyback as in just a piggyback controller. Allows you to adjust fuel and timing as the factory ECM is not flashable.
    URD kits:
    http://urdusa.com/Fuel-Upgrades-URD...for-TRD-5VZ-FE-Supercharger/product_info.html
    As supercharger oil, you can use just the GM oil. It's the same thing. Magnuson makes both the GM and TRD superchargers.
    http://www.summitracing.com/parts/cei-109055/overview/
    Depending on how many miles are on your SC, you may want to consider the full nose cone kit:
    http://trdparts4u.toyotaofdallas.com/Scripts/prodView.asp?idproduct=-8881
    TRD parts offers the full oil kit as well:
    http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-8080
  7. Jan 8, 2014 at 12:14 PM
    Grizzly Guy
    Jack
    Oregon city
    Okay that make sense, it's only got about 40,00 so I'm good. I put a hole in my cylinder wall at 80,000 on the block. I did the bigger injectors at 70,000 could the lean out of caused this? Cuz 40,000miles on the motor had another SC put on and a bigger pulley but didn't put the injectors in tell 70,000 on the motor.
  8. Jan 8, 2014 at 12:23 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Rods are the weak link in the truck. Pinging can cause a rod to bend/break (and consequently shoot out the side of the block or oil pan). Essentially when unintended ignition early in the compression stroke happens the piston will be shot up with increased pressure. It's called preignition.
    But to do that...you'd seriously have to be womping on the truck and and pinging the shit out of the engine. It's a lot easier and cheaper to lift off the throttle.
  9. Jan 8, 2014 at 12:31 PM
    Grizzly Guy
    Jack
    Oregon city
    Okay thanks for all the good info, any reason why I have a pin hole in the cylinder wall? I'm leaking exhaust gases into the cooling system so I can't get the air pocket out causing it to overheat. I found this out after doing the Head gasket
  10. Jan 8, 2014 at 12:35 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    FIC meaning front mount intercooler?
    if the 3.4 s/c is the same as the 2nd gen 4.0l s/c, it is liquid cooled. you will have an "intercooler", but it just looks like a small square radiator that mounts in front of your existing engine radiator, and it looks nothing like what you would see on an evo or sti if thats what you're asking.
    not the best picture, but here is my xrunner that was supercharged. you can see the coolant pump for the s/c under the grill. and the small square radiator is for the supercharger coolant system. you cant really see it unless you're looking for it
  11. Jan 8, 2014 at 12:39 PM
    Grizzly Guy
    Jack
    Oregon city
    No u was talking about a fuel ignition controller know I know it's called a piggyback
  12. Jan 8, 2014 at 12:40 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    3.4 SC is nothing like the 4.0.
    You can't run an intercooler with them.
  13. Jan 8, 2014 at 12:41 PM
    Detective_Dan
    Colorado Springs
    ah, gotcha
  14. Jan 8, 2014 at 12:47 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    there is a guy on here that runs an AEM FIC with larger injectors and has no problems.
  15. Jan 8, 2014 at 3:43 PM
    Grizzly Guy
    Jack
    Oregon city
    I* not "u"
