3.4 Tacoma engine miss
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaman27, Aug 5, 2015.
  1. Aug 5, 2015 at 10:48 AM
    Tacomaman27
    Tacomaman27 [OP] Active Member
    Got a 4x4 v6 Tacoma the truck will idle fine but want take gas it hesitates an backfires through the intake an out the air filter box. Truck will only idle can't really move out of its tracks I changed the maf still no luck. The engine light is on but can't drive it to a parts store to get it scanned. Any help ?
  2. Aug 5, 2015 at 5:54 PM
    Tacomaman27
    Anyway think I mighta solved the problem. Noticed the converter getting hot
  3. Aug 6, 2015 at 1:52 PM
    Tacomaman27
    Replaced the converter today. Still same way. Any help ? ?
  4. Aug 6, 2015 at 2:01 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Have you tested the Throttle Position Sensor?
  5. Aug 6, 2015 at 2:13 PM
    Tacomaman27
  6. Aug 6, 2015 at 2:26 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Change TPS if you have one
    Clean Throttle Body and IAC with the proper fluids.
  7. Aug 6, 2015 at 3:08 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    check spark plug, my number 3 plug was crack and it back fire through the intake.
  8. Aug 6, 2015 at 6:16 PM
    Tacomaman27
    Could a coil pack do that to. Now the engine light went off
  9. Aug 6, 2015 at 7:10 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    you can order scanners off the internet for pretty cheap. i got an ELM327 from ebay for like 8 dollars and the android app for 3. but you should check the CEL before anything! it knows what's going on and where to look,.
  10. Aug 6, 2015 at 11:00 PM
    00yotasr5
    lee
    merced, ca
    it could be a possibility but I rule that one out after swapping coils around. oem plugs btw, small hairline crack on the porcelain (3k only).
  11. Aug 7, 2015 at 2:05 PM
    Tacomaman27
    Changed plugs an fuel filter still same way
  12. Aug 7, 2015 at 2:09 PM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Sounds electrical, have you checked for chewed wire harnesses?
    How do your o2 sensors look? fully plugged in to wire connection?
  13. Aug 7, 2015 at 4:54 PM
    Tacomaman27
    Haven't checked the wiring but I did notice a o2 sensor was loose and I tightend it back
  14. Aug 7, 2015 at 5:01 PM
    CodeSeven
    Serge.
    Coachella Valley
    can't be an O2 sensor if youre having legitimate backfires. it has to do something with the ignition. that being: coil, coil boots, wires, plugs, crank/cam sensor, ignition control module. slim chance of being an injector or the computer. you really need to run a diagnostic machine on it.
    it COULD be a bad intake or exhaust valve allowing the explosion to pull back at the wrong times. but then again, a bad valve spring, keeper, rocker, camshaft lobe, and/or pushrod could do the same thing. check for compression to rule out all of these!
  15. Aug 7, 2015 at 5:02 PM
    CodeSeven
    Serge.
    Coachella Valley
    Just realized something!!!
    if youre using platinum spark plugs, they have a much higher resistance than stock nickel, copper or even iridium. They might be putting a LOT of strain on your coils. enough in fact to give bad spark!
  16. Aug 7, 2015 at 5:23 PM
    00yotasr5
    lee
    merced, ca
    hmm... getting a code reader that can read post mil light be good. One thing I would suggest is having Toyota do a health check, that scan can tell you many things that a code reader can't do.
  17. Aug 9, 2015 at 7:39 PM
    Tacomaman27
    Got them from Toyota dealer. There dual denso
  18. Aug 10, 2015 at 8:25 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Could be a bad wire, especially if you already swapped coils around and checked plugs.
  19. Aug 11, 2015 at 1:32 PM
    Tacomaman27
    I scanned it today. Didn't show any codes So far I have switched the coil packs around put new plugs an a fuel filter.
  20. Aug 11, 2015 at 4:15 PM
    Tacomaman27
    Also just ruled out timing belt an timing all in good shape
