3.4 Tacoma engine miss
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaman27, Aug 5, 2015.
  1. Aug 11, 2015 at 8:38 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    check for compression. essentially you remove the EFI fuse/relay and put a in place of each spark plug then crank the engine (by hand or key) 1 cylinder at a time, and see if you get pressure to hold. if it does hold, your good. if the needle never moves. you have a problem with the valves of that cylinder. head rebuild time!
    btw, the gauge should be reading around 180-200 psi per cylinder. if your not around there for all cylinders (less than 140 or not within 5% consistancy), you should take the heads in to be rebuilt.
  2. Aug 12, 2015 at 6:08 PM
    Tacomaman27
    Tacomaman27 [OP] Active Member
    Got her going today. Had a injector plugged an a brake caliper stuck not letting it pull. Thanks everyone for the help
