3.4 Tacoma engine rattle at 3,000rpms
Discussion in '1st Gen. Tacomas (1995-2004)' started by Eatbeers1stgen, Feb 20, 2020.
  1. Feb 26, 2020 at 3:38 PM
    #41
    Eatbeers1stgen
    Eatbeers1stgen [OP] Well-Known Member
    2001 Toyota Tacoma 4x4 manual
    Ome front coils and shocks (881) All pro rear leafs Custom welded front Baja bumper Elocker from trd Tacoma with low range wiring harness.
    Hmmmmm
    GQ7227 likes this.
  2. Feb 26, 2020 at 3:49 PM
    #42
    GQ7227
    GQ7227 mw survivor
    J A Y
    it will be about 3 or 4 months until the A/C needs to be turned on
    perhaps it worked itself out of the system and will not return
    no need to worry about it now if its not one of the heat shields rattling?
  3. Feb 27, 2020 at 4:44 AM
    #43
    GQ7227
    GQ7227 mw survivor
    J A Y
    i approve of ALL of this, who or whom are these a lot of people?
    is there any possibility the new aftermarket windshield was put in improperly to induce some mostly wind related rattles that are totally different vibe than the A/C related one
  4. Feb 28, 2020 at 3:34 AM
    #44
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Multiple threads ive seen on this forum. It's absolutely possible that an improperly installed windshield could cause it. Especially if it only started happening after the new windshield.
    GQ7227[QUOTED] likes this.
  5. Feb 28, 2020 at 3:37 AM
    #45
    FirstTimeFirstGen
    David
    Pacifica
    Start tapping on stuff with your hand or a small hammer til you replicate the noise. Eventually you'll find something loose that will sound like the noise you're getting while driving
  6. Jan 20, 2021 at 4:25 PM
    #46
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    THANK YOU!! @Eatbeers1stgen
    I’ve had this 3000 rpm rattle since I’ve bought my truck and it’s stumped me till
    I saw this thread the video. Sure enough I’m missing those bolts. I placed and nut and bolt in the bigger of the two and the rattle is nearly gone!! Do you remember what size the smaller threaded hole is?
  7. Jan 20, 2021 at 5:01 PM
    #47
    Eatbeers1stgen
    I’m not exactly sure the size. Just tried all my spare nuts until one fit! Glad it helped you. I was stumped forever until I looked under there.
